Old 11-12-2014, 07:22 PM   #71
Sven59
HAMMER PILOT
Sven59's Avatar
Drives: 13 ZL1#182, 85 CJ7, 16 Silverado
I think the lt4 (650hp) with a 8spd auto and a diet would put it faster than both. But just to be sure take it up to 700 even and blow their doors off.
Via lightning from a large Hammer.
"DO YOU WANT ME TO PUT THE HAMMER DOWN?"
Sven59 is offline   Reply With Quote
Old 11-12-2014, 07:28 PM   #72
96MrBass
96MrBass's Avatar
Drives: GM
Lol 650 and a small diet would be sweet and anything more might just be king of pony cars and not just good at one thing.
Roto- Fab Cai, SLP 1 3/4" headers, 3"X pipe, LM2 cat back, Comp Cam & AI Heads, SLP UP, RPM Tuned, GPI Intake, Vmax TB, ADM Air Scoop, 3.91 Gears, Gforce driveshaft, Braille 21#, Elite Catch Can, Pfadt Tie Rods, Diff Bushings and Trailing arms, Eibach spings & sways, BMR cradle bushings, Nt555r's.
96MrBass is offline   Reply With Quote
Old 11-12-2014, 08:11 PM   #73
txferrari
txferrari's Avatar
Drives: 2016 Z06/7.
Originally Posted by Busabob View Post
If you plan on making more power start with tires. The OE Goodyear's are abysmal, won't hold 578 rwhp worth a damn. Can't wait until these things are toast so I can get some RE11's or Pilot Sports.
I'm with you. Just shows you how much I'm off on the Zl1. I bought my Z in Aug. Nice and hot, so the tires got nice and sticky. I thought the Goodyears were good tires. Whoa, now it's 40 degrees and these tires don't stick for nothing. I drove 60 miles today and I was still getting squirley. I'll def be looking for different tires when these go bad.
There's only 2 people I trust. One of them is me, the others not you.
txferrari is offline   Reply With Quote
Old 11-12-2014, 08:28 PM   #74
Sven59
HAMMER PILOT
Sven59's Avatar
It should come stock with pss and drag radials optional.
Old 11-12-2014, 09:29 PM   #75
jessrayo
Speed Freak
jessrayo's Avatar
Drives: 2013 ZL1 Camaro, 2016 Camaro SS
Originally Posted by mylftft View Post
Get the right size turbos & you'll love it! My car is very drivable & the power is linear!
The problem with my turbos is that they were never designed to run in just turbo mode, they were designed to run with a supercharger on the car also. They have huge housings and deliver tons of boost at high rpm, they are seamless if the supercharger is on the car to spool them up...... that was the original plan, but it did not pan out. No matter what we did you just could not push 22 pounds of boost through the supercharger coolant bricks. If the housings were redesigned and wastegates and springs were set-up to run turbo only it would have a lot broader and more liner power band. But no matter what you do to a turbo it does not have the low end torque below 3000 rpm that you get with a supercharger.
Rather than completely rebuilding my turbo system I plan on rebuilding the supercharger bricks and adding huge bypass ports, this will allow the car to run exactly like a supercharged car to say 3800 rpm and then it will transition to the turbos and bypass the supercharger on the top of the powerband. At least that is the theory. I'm still several months away from this... There are still a lot of little things to work out. My car is at ADM again.
2016 SS -AGP twin Borg Warner 7163 EFR's, LT4 mechanical pump, LT4 injectors, Walbro 255 low side, Castrol SRF. 734whp/759 tq
2013 ZL1 -ADM - 427 LSX 6 bolt, O-ringed block built by LME. Twin PT6466 turbos. RPM custom manual trans, RPS Quad carbon clutch, 9" Hendrix rear diff & axles. ADM/squash fuel system, Ron Davis radiator, Spal fans, AGP air to air, turbo plumbing. LPE oil cooler, rear bushing upgrade, roll bar...etc. rwhp 1400+... 212.5mph, best Texas mile to date.
jessrayo is offline   Reply With Quote
Old 11-12-2014, 09:31 PM   #76
Sven59
HAMMER PILOT
Sven59's Avatar
You need to write a book!
Old 11-18-2014, 05:20 AM   #77
PonyKiller74
PonyKiller74's Avatar
Drives: 2012 Triple Black ZL1 M6
Send a message via AIM to PonyKiller74 Send a message via Yahoo to PonyKiller74
Originally Posted by SSmokinSS View Post
Why is more Horsepower good?
CenterForce DYAD Dual Disc Clutch, JDP stage 2 Clutch Reservoir, Rotofab CF CAI with Big Gulp and WW Reservoir Relocate, Stainess Works LT Headers and Retro Cat-Back with Cat Delete, MGW ST Shifter with custom Knob, CF Tail light Bezels, more to come...
Build Thread for my Z is in the works.....
PonyKiller74 is offline   Reply With Quote
Old 02-15-2015, 05:01 PM   #78
96MrBass
96MrBass's Avatar
Drives: GM
Thought I'd revive this and see what happens since a few video's have surfaced with ZL1's and hellcats lol.
Old 02-15-2015, 06:47 PM   #79
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Drives: 13' ZL1 Red M6
Nothing really changed IMHO...
Mods:
Old 02-15-2015, 08:42 PM   #80
HooninZL1
Drives: 2015 ZL1 hoonin machine!!!
Too much money, too much sex, and too much horsepower. These are things that do NOT exist! Like unicorns and dragons. Something we all want to see but never will.
HooninZL1 is offline   Reply With Quote
Old 02-15-2015, 08:45 PM   #81
Sven59
HAMMER PILOT
Sven59's Avatar
Nothing will change until the next series of reviews hopefully involving Randy Pobst and the same track and we will see some numbers and opinions worthwhile.
Old 02-20-2015, 03:31 PM   #82
JFWJR179
JFWJR179's Avatar
Drives: 2022 Camaro ZL1 Convertible A10
Yes - 2016 ZL1 needs more HP
Similar to Dodge Hellcat 700 HP from factory
Twin screw supercharger and other improvements
JFWJR179 is offline   Reply With Quote
Old 02-21-2015, 05:35 AM   #83
96MrBass
96MrBass's Avatar
Drives: GM
I wouldn't think it would need quite that to compete with gt5 and hellcat.
Old 02-21-2015, 08:19 AM   #84
scoticus.rex
LTC, USA
scoticus.rex's Avatar
Drives: Hobbes - 2013 Camaro 2SS RS M6
What does "need" have to do with it???
_____________________________________
~Rex
scoticus.rex is offline   Reply With Quote
