06-09-2019, 01:41 PM | #1 |
Drives: 2017 SS Convertible Fiftieth Anniv Join Date: Jul 2018
Jet MAF Sensor
Anybody have any experience with the Jet MAF sensor? I installed it exactly as instructed, and have been getting a CEL for too Lean Bank 1 and 2. I can clear it with a scan tool, but comes back every time. Only other mod is a K&N Blackhawk CAI. Car is a 2013 SS convertible with the L99. Any advice would be appreciated.
06-09-2019, 05:16 PM | #2 |
Drives: 2010 Camaro 2SS Victory Red 6M Join Date: Apr 2015
Shoulda went with an OEM unit.
2011 2SS 6A Red Jewel Metallic, Vararam Tune CAI, Magnaflow 3" Competition c/b, Speed Engineering 1-7/8 LT's, Circle D 5C, M/T 275/40R20 S/S, HPTuners tune by Ryan@GPI
12.3 @ 112 ACM as of 12/22/19 Gone on 12/28/19 R I P 2010 2SS 6M Victory Red/Black (old ride) CAI intake, Speed Engineering 1 7/8" LT's, X4 base tune, Flowmaster Outlaw axle-back. 12.6 @ 115 SAR as of 9/19/15 Gone but never forgotten. |
06-09-2019, 10:52 PM | #3 |
Agreed.
I have not read too much good about these type of MAFs. I have read more of people with issues afterwards than I have seen of gains. From what I understand, they are basically falsifying or padding the frequencies in order to fool the PCM. I think if they were worth it, the Camaro/Vette LS community would be all over them. We are not. I know they are very pricey too. Your money is better spent elsewhere, IMHO.
06-10-2019, 12:03 AM | #4 |
Drives: 2014 Camaro SS L99 Join Date: Nov 2017
+2, Swap it out and see if the issue persists
MODS: GPI MAX Package ported and milled heads+(229/250,111 LSA),Johnson 2110 Lifters,BTR .660 Springs,CHE Trunnions,C5R chain,DSX Flex Fuel kit,LSA Injectors,ZL1 Fuel Pump,MAMO Ported MSD Intake manifold,BOWhite ported Throttle body,25% UDP,CAI Intake,Intake Scoop,Kooks 1 7/8 headers,Borla attak catback,Elite catch can,BMR Motor mounts,CircleD 5C 4000-4200 Torque converter,ADM trans cooler,Jannetty Trans dipstick,DSS Aluminum Driveshaft,3.91 Gears,Eaton TrueTrac,JRE Billet caps,BMR Trailing arms,BMR Toe rods,BMR rear sway bar,Pegasus Solid sub frame bushings,DSS 1,000HP Axles
