07-12-2016, 12:24 AM | #1 |
Drives: 22 ZL1 1LE Join Date: Nov 2014
Eagle F1 question
The Eagle F1 G:2 are right and left thread pattern. What would happen if put 2 lefts in the rear.
07-12-2016, 12:57 AM | #2 |
Drives: 2014 2ss 1le Join Date: Sep 2011
One tire would be running with the tread pattern backwards
07-12-2016, 07:56 AM | #3 |
Drives: 2014 Camaro 2SS 1LE NPP Join Date: Nov 2013
The car would move in continuous circles. You'd never be able to go anywhere.
My thoughts on some things:
07-12-2016, 08:13 AM | #4 |
The BBOMG fill-in husband
Drives: 2015 2SS/RS 1LE AKA V1LE Join Date: Aug 2010
Leftersteer
UPSTATE C5 MEMBER
07-12-2016, 09:28 AM | #5 |
Drives: 2013 1SS 1LE Black - Std Exhaust Join Date: Mar 2013
Nothing a catch can or two would not fix!
PS: I add this to negate my smart assed remark. I keep a tire as an emergency spare. I can not tell you if it is a right or a left because it would not matter. As others have said, performance will be reduced (most likely to be noticed in wet weather conditions), but to get around until a new proper side tire can be purchased and installed, you will be just fine. Last edited by gajagfan; 07-12-2016 at 10:09 AM. |
07-12-2016, 09:30 AM | #6 |
Resident nomad
Drives: 2014 Summit White 1SS/1LE Join Date: Nov 2015
Well, assuming you're question is seriously being asked, you'd probably not notice too much in handling unless you drove the car at the tires limit. The tires tread design was developed with directional stability, grip and the need to shed water from under it occasionally. If you're running it the opposite of it's intended direction, I'm sure you understand that negates what the designers intended. For a short period of time, if you're strapped for cash, you're not gonna damage anything. I wouldn't recommend it for any other reason.
Sold:
2007 Z06 2002 Viper GTS/ACR 2003 Z06 1965 FFR Cobra 2012 Nissan 370Z ADM LSA Stage II, Roto-Fab CAI, Kooks LTH/HFC's, Phastek CC, ported TB, Mishimoto radiator and oil cooler, BC Racing ER Series CO's, JPSS 32mm Black Magic rear bar, JPSS front inserts, R1 Concepts Premier slotted rotors/Goodrich SS lines, Schroth ASM harness, MGW flatstick, Brey-Krause HB, Tuned by NicD, at Cordes Performance Racing. |
07-12-2016, 09:39 AM | #7 |
Drives: 2015 Camaro 2SS/1LE Join Date: May 2015
The tire installed incorrectly will wear out faster and by looking at the thread pattern and how it draws water from the center ---> out......it would have degraded wet road performance...which is already bad to begin with.
07-13-2016, 01:49 PM | #8 |
Drives: 2013 2SS/RS/1LE Join Date: Apr 2010
