01-26-2021, 03:38 PM | #1 |
Drives: 2018 Camaro SS 1LE Join Date: Sep 2018
Goodyear replacement depth
I feel the fronts are too worn on my 1LE. The outer edge is slick. The inner edge looks just ok. At what depth do you swap these tires? They start with 7, so if you replace them at 4 or 3, you haven't gotten much life out of them.
01-26-2021, 04:17 PM | #2 |
Drives: 2018 Camaro 1SS 1LE Join Date: Feb 2020
I probably have about 0.5 and am starting to think about replacing them.
I have just under 11000 miles, mostly spirited canyon type driving. |
01-26-2021, 04:59 PM | #3 |
when they got cords showing lol
01-26-2021, 06:27 PM | #4 |
Drives: 2018 Hyper Blue 2SS 1LE Join Date: Aug 2018
The thing to remember is that the outer two tread blocks become one at about 4.5mm depth. Only way to know how much is left is to check the tread depth holes that are molded into the tread. Look for some rectangular holes near the edge. That is where you take a tread depth measurement.
Edit: I have circled in red the holes you should look for. The groove identified by the green line is not as deep as the other grooves. This is so as the tire wears the outer edge becomes more like a slick with less voids and less tread squirm.
2018 Hyper Blue Metallic 2SS 1LE with Nav, PDR, and track alignment
1:34.20 Willow Springs Big Track |
01-26-2021, 07:33 PM | #5 |
+1 when the cords show
But I’ll add that I drive my wife’s car in the rain when the tires go near slick then I run them in dry weather until cords show. |
01-26-2021, 08:38 PM | #6 |
Drives: 2023 CT5 Blackwing Join Date: Sep 2016
When they cord.
My fronts always cord inside edge 1st.
2017 HBM SS 1LE
Sold 2023 Wave Metallic CT5-V Blackwing M6 |
01-26-2021, 09:38 PM | #7 |
BTW - that is the result of two road trips from Orlando to Boone, NC to VIR (two days at VIR) back to Boone, back to Orlando and then a month later up to RRR in Savannah. All of that was with -2.5F camber.
2017 HBM SS 1LE
01-26-2021, 10:43 PM | #8 |
Who Needs to KNOW?
Either worn or heat cycled out... ideally when both happen at same time!
ing for grip.
01-27-2021, 12:35 PM | #9 |
Id run the wear bars/indicators than a depth measurement which with these kind of tires IMHO a measurement and whatever that standard for tread depth might, be isn't too applicable with these type tires.
01-28-2021, 04:05 PM | #10 |
Drives: 22' Porsche PDK GT4 Join Date: Mar 2018
I only drive on the street , albeit sporty street driving and I have the track alignment.
My wear rate is about 2:1 Rear to front. When the rears are slicks, I replace all 4. Replacing all 4 keeps the car very neutral. As my rears wear, my car goes from neutral to slight oversteery. This last time, I only replaced the rears and I now have understeer.
Current:
22' Porsche PDK GT4 (MCS 2-way remote dampers) Previous: 18' NFG 2SS 1LE (ZL1 1LE solid rear cradle bushings & Corsa Exhaust) 16' F80 M3 (Ohlin R/T Coilovers) 13' Audi TTRS (APR Stage 1, MSS Springs) 09' C6 Z06 08' E90 M3 06' 335i (KW V2 Coilovers) 03' C5 Z06 |
01-28-2021, 05:22 PM | #11 |
Drives: 2020 SS 1LE (previous: 2017 SS 1LE) Join Date: Mar 2012
Check your toe. Way too much rubber left on yours to chuck them otherwise. Here's pic of mine at 2.6 camber. Cheers!
01-28-2021, 06:24 PM | #12 | |
Alignment was fine. It was the 4,000 highway miles that killed them. The VIR sessions didn't hurt, either.
2017 HBM SS 1LE
01-28-2021, 08:32 PM | #13 |
Ya, abrasive track will cord them. That's what happened to me, but only once. Never had one cord just from DD. By and large camber wont cord a tire, but excessive toe will make fast work of it. I am running zero toe in the front now. No complaints regarding turn in etc. Cheers!
01-29-2021, 07:54 AM | #14 | |
Drives: 2013 C6Z06 Join Date: Nov 2016
My obligatory tire photo to show you up With all of that said, in regards to the OP, it doesn't seem like he is tracking the car if he doesn't know much about these tires. I would recommend buying different tires when the time comes and getting an alignment at the same time.
Old Ride: 2016 Callaway SC630 Camaro SS
