TireRack
Old 07-09-2014, 07:19 PM   #1
blackTT600
Drives: 2011 2LT M6 SC
Numb steering
I hears some where that there were some technical bulletins to address numb steering in early cars? I have a 2010 production 2011 model year and some times it feels very numb. Is there some thing I can do?
Thanks.
blackTT600 is offline   Reply With Quote
Old 07-10-2014, 10:21 AM   #2
rockrau
rockrau's Avatar
Drives: 2010 2ss red LS3
I do not know about the TSBs, but a performance alignment will shurely liven up the steering and handeling.
Pedders Pace Car Kit with ZL1 sway bar conversion & camber bolt kit.Lowered 1.5". 1LE tires & wheels. CAI air intake. Anvil CF rear spoiler.MGW shifter. 1 7/8" Kooks LT headers & HF cats.V-Max ported TB. Tuned.
rockrau is offline   Reply With Quote
Old 07-10-2014, 10:38 AM   #3
BMR Sales
BMR Sales's Avatar
Drives: Race Car
Not completely sure what you mean by "numb", but this (BK022) Front Suspension Bushing Kit would probably help in your quest.....along with a good performance alignment as rockau mentioned.
Old 07-10-2014, 11:56 AM   #4
Chevrolet Customer Svc
Chevrolet Customer Svc's Avatar
Drives: GM Vehicles
Thanks.
blackTT600,
Sorry to read about the steering concerns with your Camaro. Although you're seeking thoughts and opinions, I would be happy to communicate this situation with the designated Customer Experience Manager at your preferred dealer if you feel an official diagnosis is necessary. Feel free to message us privately if you'd like to proceed, or discuss this situation further.
William R.
Chevrolet Customer Care
Chevrolet Customer Svc is offline   Reply With Quote
Old 07-10-2014, 04:21 PM   #5
blackTT600
THANK YOU of Your response. Actually I just had that installed, Have not gotten the car back yet. but very excited. I was actually the full race kit!
Old 07-10-2014, 04:24 PM   #6
blackTT600
Originally Posted by Chevrolet Customer Svc View Post
blackTT600,
William R.
William,
Thank you as well for your response. I will keep that in mind. I love the car, but sometimes I just wish there was more feeling in the wheel. I don't feel the need to do anything about it right now. But I thought I heard some one talking about this.
Old 07-10-2014, 04:25 PM   #7
blackTT600
I just want more communication from the road through the wheel.
Old 07-12-2014, 12:06 PM   #8
JusticePete
JusticePete's Avatar
Drives: Camaro Justice
The answer is in your alignment specs.
Set the front Toe to 0.00 neutral.
Front Camber -1.00
Rear Toe IN 0.12
Total Rear IN Toe 0.24
Rear Camber -0.00 to -0.70 Less rear camber is better
Your rear tires will last longer and your front tires just a bit less than a more conservative alignment.
Your steering will feel more on center and precise.
A split front lower inner control arm bushing will offer no benefit over the excellent OEM designed steel jacketed rubber bushing with a 'barrel' style ferule that is suspended in about 1/8" of rubber.
Get your 5th Gen aligned to these specs and you think you bought a new steering rack or did suspension mods.
Old 07-12-2014, 01:06 PM   #9
Jrichards73
Jrichards73's Avatar
Drives: 2011 2SS/RS Victory Red
Got the poly bushings on mine and after three trips to get it aligned and wheels balanced I still have a high speed vibration. It isn't terrible but annoying, it seems to be slowly improving so maybe it is a break in?
Updates: BTR Stage 2 VVT Cam Kit w/Smith Brothers Trunnions, Fluidampr, RX catch can, B&M Trans pan mod, Kooks Black Headers, Borla S-tunes, Eibach Multi-Pro-R2 coilovers and Swaybars, BMR Full Bushing kit with Toe and Trailing arms, RB Rotors w/EBC Pads, GForce 1400 Axles (now on order). AVH-X5800BHS in Scosche GM5201AB.
Jrichards73 is offline   Reply With Quote
Old 07-12-2014, 03:36 PM   #10
JusticePete
Your vibration is rotational and not in the suspension.
Out of round wheel, hub or rotor
Improper wheel lug nut torque
Improper balance
Bad tire
Old 07-12-2014, 09:58 PM   #11
wakespeak
wakespeak's Avatar
Drives: 2020 ZL1 1LE
I second the lug nut torque (140 lbs/ft).
2020 ZL1 1LE [Moroso SC Expansion Tank, otherwise stock]
wakespeak is offline   Reply With Quote
Old 07-17-2014, 08:02 AM   #12
2014CamaroZL1
2014CamaroZL1's Avatar
Drives: 2014 CRT ZL1
Front Camber -1.00
Rear Toe IN 0.12
JusticePete,
Can these specs be obtained with stock hardware ?
Or will aftermarket bolts, plates, or such be required ?
Thanks.
2014CamaroZL1 is offline   Reply With Quote
Old 07-17-2014, 08:33 AM   #13
JusticePete
They can
