Vararam
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Members Classifieds - Parts for sale or wanted > Autos For Sale / Wanted
Old 07-08-2019, 11:54 AM   #1
Blown427
Drives: 2011 Camaro SS
2011 Camaro SS LSx 427, lots of nitrous, fully built and ready to go.
All,
I am selling my 2011 Camaro that is setup and ready to hit the track and drive home! I have a laundry list of parts that are on this car that I am still putting together as everything is pretty much brand new on the vehicle. If you have immediate questions feel free to contact me at any time. I am asking 45k for the car as the body is clean with 7700 miles on it! Never seen rain, always garage kept.
Text or call to 8479896696
Blown427 is offline   Reply With Quote
Old 07-08-2019, 11:59 AM   #2
Blown427
It does have a parachute setup on it, just not in the current pictures that I have.
Old 07-08-2019, 01:45 PM   #3
Blown427
Latest engine pic.
Old 07-14-2019, 11:39 AM   #4
Blown427
Details:
- Kirkey Seats.
-6 Point weld in chromoly cage with swingouts
-VFN fiberglass hood
-Midwest chassis chute mount with release and Stroud chute
-Weld S71 beadlock Wheels 18x4 front and 15x10 in the rear with brand new 30" DOT Slicks
-Upgraded gears with Detroit locker 4.11 gears in the rear with 1400HP DSS Axels (I also have a 9" conversion rear end that I might be keeping with drive shaft)
-PFADT suspension components and solid motor mounts
-QA1 adjustable front coilovers in front.
-Carlyle 15" conversion with Strange rear coils.
-BMR rear components all around in the rear.
-All lights work (including factory HID) and all interior components
-Holley Dominator HP with upgraded 7" dash screen.
Long Block Break Down:
-GMPP LSx block punched to a 427ci 12.5:1 Compression
-K1 Technologies Crankshaft Shaftech Balance Crankshaft to 1850 BW, Counterweights, Magna Flux Insp, Check TIR
-Diamond Custom Dome Piston, Int Mill Maxi-Lite, Offset Pins, Pin
Fit, Dbl Pin Oilers, Inboard Forging, H-13 Piston Pin .927D,
Support Rails
-Callies Ultra H-Beam Rod SBC 6.000 2.100
-Clevite H-Series Rod Bearing - Standard Size, TM-77, Chevy,
Small Block
-Clevite H-Series Main Bearings
-Cloyes Hex-A-Just Timing Set - Hex-A-Just, Single Roller, Billet
-Steel Sprockets, Chevy, 6.0L, Set
-Melling Performance Oil Pump - Standard-Volume, Chevy,
4.8/5.3/5.7/6.0L, Each
-ARP Cam Bolt Kit - High Performance, Black Oxide, M8, Chevy,
5.7L, LS1,Setof3
-ARP Balancer Bolt Kit - Chromemoly, Black Oxide, 12-Point,
Chevy, 4.8, 5.3, 6.0L, LS1, LS6, Each
-Fel-Pro Conversion Set Gasket - Chevy, 4.8, 5.3, 5.7, 6.0L, Set
-Total Seal Piston Rings
-COMP Cams Custom Ground Camshaft Core - Camshaft,
Custom Grind, Race Roller Tappet, Chevy, Small Block, LS1,
-Durabond Cam Bearings - LSX
-Crower Shaft Mount Rocker Arms
-GMPP-DR CNC Ported heads 6-bolt heads
-PAC Racing Springs Dual Spring 400 Series Retainer - Titanium
-LS retainer for PAC-1530, 1335 Valve Springs. Lock angle: mini 8
-PAC Valve Springs - DUAL SPRING 1.300 OD, 1.800, .800 LIFT
-PAC Racing Springs Steel Spring Seats (0.060 Thickness)
-PAC Racing Springs Steel Valve Locks - Mini 8 degree - Radius
-Groove - +0.050 Install Height
-Isky Red Zone Solid Mechanical Link Bar Lifters - Needleless
-Bronze Bushings, EZ Max
-Chevrolet Performance Valley Cover Gasket
-Holley Hiram Setup with dual FAST 4500s
-Nitrous Outlet Hi-Ram kit with two stages of nitrous, two 10lb bottles setup to take up to a 700 shot.
Exahust:
-American Racing 1 7/8 headers ceramic coated.
-Custom dual 4" aluminum exhaust from the headers back. All v-band ( I have more pictures of this)
Transmission is also new and details are below:
DRC Stage 4:
- Race prepped OEM case, bead blasted, clearanced, deburred and painted black
- Clean neutral reverse manual with trasnbrake.
- Cast aluminum pan
- Needle bearing through out
- aluminum direct drum with 34 element sprag
- 300mm input shaft
- J.W. Ultrabell
- PTC billet aluminum converter stall speed set at 4400
- TCI Outlaw Shifter
Fuel System
- 160 lb/hr Holley Injectors
- Aeromotive Eliminator Stealth System
- Stainless braided lines, 100 micron filter, etc..
Most likely I am missing a bunch of stuff. Feel free to contact me for more details.
Old 07-20-2022, 10:26 AM   #5
SFR7771
Drag and Drive is Life
SFR7771's Avatar
Drives: 2010 Camaro 2SS RS A6 LS3 Whipple
What size back tires is that just curious Thanks
My build link... https://www.camaro5.com/forums/showt...4#post11077544
2010 2SS/RS/ Mods, Whipple, 1000cc injector, 102MM TB, Innovation West 10% OD pulley set up 8 rib, AGP twin 450 fuel system w flex on E85, CAI K&N, LT with OR Cats aka no catalytic converters, Coils and wires, 3" exhaust with mufflers, Oil catch can, 2015 ZL1 9.9 3.23 ratio, BMR upper Lower control arms, 15"conversion, BMR Anti Roll Bar 315/60/15 ET street slicks
1972 El Camino SS 565BBC 950HP, All TRZ suspension
SFR7771 is offline   Reply With Quote
Old 07-20-2022, 10:48 AM   #6
joshnmn
2&THEHIT
joshnmn's Avatar
Wish I needed this. It looks amazing
Old 07-26-2022, 04:11 PM   #7
Mighty1
Mighty1's Avatar
Drives: 1967 Camaro RS; 2013 Camaro ZL1
Yeah this thing looks amazing!
Mighty1 is offline   Reply With Quote
