TireRack
Old 05-10-2022, 07:48 PM   #1
Royal Tiger
Where does this go?
It says there is a pop off cover, which I have seen on other cars, but not on a 5th gen. I’m guess you’d have to cut a hole in the bumper?
Old 05-10-2022, 07:53 PM   #2
Camaro2ss2010
Camaro2ss2010's Avatar
Drives: 2010 Camaro 2SSRS M6
Mine does not have one either. I have the ZL1 addons version and it mounts perfect to slide between the slots. I can take a better picture if needed this is a screenshot of a video. I marked where it needed to go before I removed the front bumper to install the bracket.
Camaro2ss2010 is offline   Reply With Quote
Old 05-10-2022, 07:57 PM   #3
Royal Tiger
Yes please do!!!
Thanks.
Old 05-10-2022, 08:06 PM   #4
Rob3D
Rob3D's Avatar
Drives: Car
That’s EXACTLY what you have to do. There’s some good write ups here if you search. The most important step is mark it BEFORE you remove the front cover and start drilling. Placement is not to far towards the outside but you don’t need it centered…it’ll look stupid. So about 12-18 inches from center…whatever you think.
Old 05-10-2022, 08:42 PM   #5
Camaro2ss2010
Car is filthy but here are some more pics. In the first pic you can see the bolt holding the mount and the threaded insert for the hook. Maybe this will help.
Old 05-10-2022, 08:46 PM   #6
Royal Tiger
Thank you!!!
Old 05-10-2022, 09:08 PM   #7
Camaro2ss2010
Thank you!!!
Anytime
Old 05-11-2022, 05:03 AM   #8
Glassman66
Glassman66's Avatar
Drives: 2014 Camaro 2SS/RS 1le
This is what you need. You have to pull the front bumper and install the support with the threaded insert. Once again GM in their infinite wisdom put in the removable cover with no threaded bumper support behind the cover.
https://www.carparts.com/details/Che...E&gclsrc=aw.ds
https://www.camaro5.com/forums/image.php?type=sigpic&userid=124840&dateline=15563  941302014 Camaro 1LE SS/RS THE MISTRESS
Glassman66 is offline   Reply With Quote
Old 05-11-2022, 06:03 AM   #9
TheFlyingBananaSS
Evil Genius of Chevrolet
TheFlyingBananaSS's Avatar
Drives: 2017 Z06, 2019 XTS, 2013 SS
This only applies to the 2014 and 15. The 2010-13 have a different front cover. No need to cut an opening. I have the ZL1 add-ons. No cutting needed. Best options for early 5th gens tbh.
TheFlyingBananaSS is offline   Reply With Quote
Old 05-11-2022, 07:25 AM   #10
BLU DUCE
BLU DUCE's Avatar
I have the ZL1 on my 2011 also no drilling. The newer camaro has to have the crash bar replaced it has the threaded hole already for mounting the Tow hook.
Old 05-11-2022, 08:42 AM   #11
demonspeed
not afraid of the wall
demonspeed's Avatar
Drives: Camaros
I went with the JDP due to being a 2013. Otherwise, had I owned a 14/15, I’d get the threaded one and swap crash bars.
2023 1LE 1SS BCD GCF JF5 MN6 SIA SLN UQT
10/13/22: 1100
Past Camaros: 13 1LE|02 SS|01 Z28|00 SS|91 1LE|91 Z28|89 IROC-Z
demonspeed is offline   Reply With Quote
Old 05-11-2022, 03:21 PM   #12
TheFlyingBananaSS
Then you would have to cut a hole out of your bumper cover
Old 05-11-2022, 03:27 PM   #13
Thunderstick
Thunderstick's Avatar
Drives: 14 Camaro LS
My 14 1Le had a removable cover over the spot you need to drill for the insert. I can remove the hook and put the cover back on and it's like it never happened.
Sent from my SM-S908U using Tapatalk
Thunderstick is offline   Reply With Quote
Old 05-11-2022, 05:42 PM   #14
AllBlackSS
AllBlackSS's Avatar
Drives: 2010 SS
Link to this one?
AllBlackSS is offline   Reply With Quote
