Old 11-05-2021, 05:55 PM   #1
Chris49066SS
Chris49066SS's Avatar
Drives: 2010 SS L99
Weird occurence for the 2nd time
This has happened twice in the last 6 months. The starter was heat soaked and started really hard, then the tach wouldn't work at all, it stayed at zero, and all the lights on the dash (stabilitrak and the others) came on, and the car had an abnormal lope. Not the usual chop but different, like a bit more natural sounding lopey cam idle. Anyone ever have this happen? Just wondering what the reason could be.
Previous PB:11.079 @ 122.99mph.. New setup time: TBD
The 11.079 pass: https://youtu.be/pz27Zq54t_E
Build thread - www.camaro5.com/forums/showthread.php?t=555371
Chris49066SS is offline   Reply With Quote
Old 11-05-2021, 06:37 PM   #2
caper
Drives: 2010 IOM 2ss/RS
https://www.camaro5.com/forums/showthread.php?t=504199
look here, there are many other threads in the same subsection
Turbonetics running 8lbs boost at 700rwhp tuned by Hi Rev, installed by K&M w/cat-muffler delete, ACS splitter, Fesler GFX, MPD1 spoiler, Custom painted Rally stripes, Cordon CR1 wheels 275/315s, Hotchkiss comp sways and end links, Barton shifter
caper is offline   Reply With Quote
Old 11-06-2021, 07:31 AM   #3
zz430camaro
zz430camaro's Avatar
Drives: 2015 1LE
Battery probably getting ready to take a shit. On GM cars a lot of time if there is a voltage issue the dash will flip out.
2015 1LE, TSP 225/236 113+3, VMAX Throttle Body, CAI with race scoop, GPI Ported Intake, Land Speed Stage 2 Heads, 1-7/8 headers, NPP exhaust, 25% Fluidampr, LT1-S Monster Clutch, 485 RWHP & 444 TQ
zz430camaro is offline   Reply With Quote
Old 11-06-2021, 08:17 AM   #4
Camaro__ss
Drives: 2013 L99
Your battery is going on hospice
Camaro__ss is offline   Reply With Quote
Old 11-06-2021, 10:38 AM   #5
caper
yeah, could be battery, could be much more involved...start with the battery though.
Old 11-06-2021, 10:56 AM   #6
camguynj
camguynj's Avatar
Before guessing/getting a new battery get a cheap $15 battery analyzer and do a load test. That’ll tell you how many volts your battery is producing. Do once before first start of day then again after car is really heated.
Old 11-06-2021, 01:01 PM   #7
Chris49066SS
Drives: 2010 SS L99
Thanks guys. I just replaced the battery 2 years ago, too. Then last year both the alternator and the starter. Went with OEM for those.
Old 11-07-2021, 01:45 AM   #8
morepowerjoe
morepowerjoe's Avatar
Drives: 2012 Chevrolet Camaro l99
I have had batteries die on me only after a couple years. Especially if you have a walmart or o'reilly battery.
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817
morepowerjoe is offline   Reply With Quote
Old 11-07-2021, 09:32 AM   #9
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
When my battery went bad it did all that funky crap too. Replaced it with OEM, and that one only lasted about 1.5 years and took a dump too, it was bad from the get go, got it replaced under warranty and been good so far. It's not the first time I have had a battery just decide to quit. Good luck.
Old 11-07-2021, 11:48 AM   #10
Chris49066SS
Drives: 2010 SS L99
If this one is bad I am going to say screw it and just get a Braille lightweight battery like I wanted in the first place. I'll get it figured out and post the fix when I can. Again, thanks everyone
Old 11-07-2021, 05:30 PM   #11
zz430camaro
Drives: 2015 1LE
Well if it ends up being a battery, the Optima's usually last a really long time. Also check the grounds, I think BoWhite had a ground issue that caused cranking problems, he cleaned up some contacts in the trunk with the battery cable on the chassis I think and it fixed it. Might ask him about it.
Old 11-07-2021, 06:39 PM   #12
InFiD3ViL
InFiD3ViL's Avatar
Drives: 2010 CGM 2SS/RS LS3 Swapped A6
I have had this exact same thing on my old battery. It was before I cammed it and remember I let it run for a minute or so since it sounded kinda cool. I didn't replace my battery right away, but I know it had happened a few times. Usually turning it off and back on again cleared it and the tach and idle would go back to normal.
InFiD3ViL is offline   Reply With Quote
Old 11-07-2021, 09:33 PM   #13
caper
it drops the sensor for the crankshaft position. probably not the best for the engine...it'll run, but timing etc is off.
Old 11-17-2021, 05:54 AM   #14
zz430camaro
Drives: 2015 1LE
was this resolved?
