10-18-2021, 12:08 AM | #1 |
Drives: 2011 camaro 2SS Join Date: Aug 2021
“What header gaskets?”- NEED ADVICE ON LEAKING HEADERS!
I have some Manzo stainless steel headers going on like 3 years. Overall quite decent build quality for some “Amazon” headers. However, I can’t get them to stop leaking at the header gaskets (like bad).
changed from oem gaskets to Felpro graphite gaskets and it ran great for about A WEEK before gradually getting worse and leaking bad again. Warped header flanges? Or am I missing some supporting exhaust hangers causing constant pressure pulling down on them? Any real advice is appreciated |
10-18-2021, 02:16 AM | #2 |
GrINned & JUICEd
Drives: 15STI, 10Expy, 10 2SS/RS M6, 47KB1 Join Date: Nov 2009
Oem has worked fine on my ARHs. A warped flange will definitely cause a leak or blown gasket, depends on material. A machine shop can level it out. Get a really good straight edge or maybe glass and use a feeler Guage. Shop had to grind down my '47 IH KB1 cast exhaust manifold.
10-18-2021, 08:03 AM | #3 |
OEM are the best gaskets if the flanges are flat. Mahle makes almost the same thing for half the price. If the flange is warped, you can try Remflex or look on Summit for ones that are thicker. If the flanges are warped, the real solution is new headers.
10-18-2021, 09:02 AM | #4 |
Instagram: Sangstah
OEMs always.
2019 SS 1LE - "CaSSandra" 2014 SS - "AleSSandra - Sold" 94 Z28 - Sold
Follow the build https://www.camaro6.com/forums/showthread.php?t=612717 |
10-18-2021, 09:33 AM | #5 |
SomeguyK
Drives: 2010 Black 2SS/RS Join Date: Nov 2014
OEM MLS gaskets. As mentioned before, I would check the flange for warps. You can have them milled flat at a machine shop.
More to come. |
10-18-2021, 09:43 AM | #6 |
KaBoom1701
Drives: 13' ZL1 Red M6 Join Date: Dec 2012
OEM gaskets only...
I'd also put a large straight edge on you header to engine block surface and double check for any warps or surface irregularities. Cheap Amazon headers maybe be to blame here.
Mods:
Roto-Fab Intake, WW Res. kit & Big Gulp Air Scoop, Elite Catch Can, ATI Super Damper & 18% OD Pulley, LF Idler pulley bracket, Metco CC breather, ID850 Injectors, Stainless Power Headers w/ ceramic coating, TR71X Spark Plugs, JMS Fuel Pump Booster, Bo White TB, Tuned by Ted @ Jannetty Racing, Ron Davis HX, D3 Reservoir, Pfadt 1" Springs, Moreno Camber Plates, ZL1 Addons Splitter guard washers, Tow Hook kit & rock guards, Hurst Shifter Billet Plus 6 Speed Short Shifter, ZL1 DRL lighting harness, ZL1 Recaro Seats. |
10-18-2021, 10:02 AM | #7 |
Yeah that seems like the best way to know for sure. I can almost guarantee they are warped now that i think about it. the graphite gasket looks more compressed on the far edges than in the middle.
10-18-2021, 10:13 AM | #8 | |
I certainly don’t disagree that them being Amazon headers could be the problem. But do headers typically warp during manufacturing/welding or while on the car? (They could have very well been leaking the day they got installed). Trying to gauge whether I should just mill these or buy new ones. |
10-18-2021, 10:15 AM | #9 |
Ya, MLS won't do much for you if the flange is warped. Back in the day, we used to soak gaskets to get more crush out of them. Gaskets have come a long way since then.
I tried milling my turbo flange, but they had to take too much material off and I ended up buying a new one. For about $300 you can get some Speed Engineering headers, which is probably your best bet unless you want to invest in a really good set.
10-18-2021, 10:18 AM | #10 | |
10-18-2021, 05:40 PM | #11 |
GrINned & JUICEd
That cast manifold was a combination, bolted together, intake and exhaust for a straight 6 cylinder. $75 total. Are you leaking from both sides? If the flanges are thin or cheaper material, it will probably warp again. If that's your problem. Also, did you torque down the bolts working from the inner to outer? Re-torque after a few heat cycles?
10-18-2021, 07:12 PM | #12 |
Get some Texas speed headers and swap them out. They are the best bang for the buck and use GM gaskets.
10-18-2021, 07:49 PM | #13 | |
I was a complete noob I dont remember the sequence I torqued them on. Material is t304 stainless. I really don't want to spend money on them if theres a high chance of them re-warping. |
10-19-2021, 08:55 AM | #14 |
OEM gaskets all the way. And as stated above, if the flanges are made of cheaper material and are thin, they WILL warp again over time if you do try to level them because you will be making the flanges even thinner than they were. This used to happen "back in the day" with bargain headers with thin mounting flanges. Good quality headers now have a pretty thick flange material and won't warp. My Stainless Power ones have been on the car 9 years now and have been off and on several times. Good luck.
