Roto-Fab
Old 09-24-2021, 11:00 PM   #1
Hitman1776
Drives: 2012 2ss convertible camaro
THE BEST SOUNDING EXHAUST?
Ok I need some input on what’s the best sounding exhaust for a 2012 ss Camaro? Ok 3.2.1.. GO!
Hitman1776 is offline   Reply With Quote
Old 09-24-2021, 11:02 PM   #2
Glassman66
Glassman66's Avatar
Drives: 2014 Camaro 2SS/RS 1le
My opinion is headers into hi for cats and stock npp opened.
https://www.camaro5.com/forums/image.php?type=sigpic&userid=124840&dateline=15563  941302014 Camaro 1LE SS/RS THE MISTRESS
Glassman66 is offline   Reply With Quote
Old 09-24-2021, 11:30 PM   #3
George-CZ
George-CZ's Avatar
Drives: 2010 2SS LS3 and 1978 STROKER 383
3" Stainless Works Retro Chambered
My life is a constant struggle with Camaro.
K&N CAI, Stainless Power longtubes, high flow cats, modified Ragazzon High Performance axle back, Soler Performance ported throttle body, Soler Performance throttle controller, RAM clutch adjuster, modified LS7 clutch kit, Tick Performance billet bearing support, Tick Performance remote bleeder, separate clutch reservoir, BMR trailing arms, BMR toe rods, Pedders Suspension cradle bushing inserts, Control Arm Bushings, Strut tower brace, oil catch can, Hurst T-handle shifter, 20mm wheel spacers, DBA brakes, QTP Cutouts, Dynosteve tune.
George-CZ is online now   Reply With Quote
Old 09-24-2021, 11:43 PM   #4
SSJ2
SSJ2's Avatar
Drives: 2010 2SS CAMARO
“Best Sounding “ will always be subjective in my opinion. I think most will agree for starters. Long tube headers with hi flo cats. After that I feel it’s a matter of opinion. Personally mine go into just a muffler delete with jpipes and I love the way it sounds There’s loads of options and many sound pretty good in my opinion just slightly different.
BBK Long tube headers, Hi flo cats, straight pipe muffler delete with j-pipes. K+N CAI, Soler Performance Ported Throttle Body, Soler Performance Throttle Controller, Phantom Grill, MGW flatstick shifter. 3.91 Gears, Ported Rod Mod Intake, ZTA Spoiler, Rohana RC22 20x10 20x11.
SSJ2 is offline   Reply With Quote
Old 09-25-2021, 01:16 AM   #5
Modernmusclecar
Modernmusclecar's Avatar
Drives: 2011 Camaro SS
This at wot. Corsa
https://youtu.be/FUTCot0MfGg
EPS CUSTOM GRIND CAM....K@N CAI....VMAX PTB.....FRANKENSTEIN STAGE 2 HEADS ...1 7/8 STAINLESS POWER CATTED LONGTUBE HEADERS...CORSA XTREME 3 INCH CATBACK.....CIRCLE D 3800 Pro Series stall...391 gears.....Ported/modded GPI intake .Forgestar drag pack with Mickey Thompson ET street drag radials AGP PERFORMANCE DYNO TUNED. 463 WHP 428 FTLBS TORQUE.
Modernmusclecar is offline   Reply With Quote
Old 09-25-2021, 07:04 AM   #6
0stones0
It don’t come easy.
0stones0's Avatar
Drives: 2010 2SS RS M6
LT headers with HFC’s to Corsa catback.
Old 09-25-2021, 07:21 AM   #7
Bigdumogre
Bigdumogre's Avatar
Drives: 2012 Camaro SS
Long tubes and a x pipe make a world of a difference. Then after that it’s whatever muffler or lack of that you like. I enjoy the old muscle car sound so flowmasters for me and it sounds like a nasty old school muscle car. If you want something more sports car sounding then go corsa or jpipes.
Bigdumogre is offline   Reply With Quote
Old 09-25-2021, 03:47 PM   #8
pyroguy
Started#gottalovethatblue
pyroguy's Avatar
Drives: ABM #831
Long tube headers with high flow cats and Solo Mach XL catback is what I've been running for years.
'10 Camaro 2SS/RS | Aqua Blue #831 of 3,903 | Silver Stripes
Check out my build thread
Old 09-25-2021, 05:19 PM   #9
G8One2
I have Kooks LT, high flow cats and NPP exhaust. I feel no need to change it. Sounds good to me and not too terribly loud when putzing around.
G8One2 is offline   Reply With Quote
Old 09-25-2021, 05:34 PM   #10
mpr3369
If you stick with stock headers & replace the primary cats with high flow cats, catback exhaust, will it throw a code? Just wondering if the HFCs will throw a code. Sorry to hijack the thread.
mpr3369 is offline   Reply With Quote
Old 09-25-2021, 07:27 PM   #11
G8One2
If it throws anything, it will be a catalysts efficiency code.
Old 09-25-2021, 07:41 PM   #12
mpr3369
So, is that what usually happens? I'm asking because I have a catback I'd like to install and if I should change the primaries to high flow when I install it, I'd rather do it all at the same time.
Old 09-25-2021, 07:53 PM   #13
Bigdumogre
Bigdumogre's Avatar
High flow cats will throw a code. Plus to have rear o2 sensors installed you have to weld in bunds into the exhaust. Gotta tune out the rear o2’s after high flow cat install.
Old 09-25-2021, 08:57 PM   #14
punk5150
punk5150's Avatar
Drives: 2014 SS/RS CRT
I second this 👍
punk5150 is offline   Reply With Quote
