Roto-Fab
Old 11-22-2019, 09:46 PM   #1
IWANTA(ss)
IWANTA(ss)'s Avatar
Drives: 13 1LE 1SS/05 ZX10/02 Silverado/14
4.11 true-trac
So my GPI built diff was dropped off today. Would like to install it Monday anything special I need like new nuts bolts washers special break in fluid?
Any help would be greatly appreciated
02 Stepside Silverado
05 ZX-10
13 1LE
14 Nightrod Special
IWANTA(ss) is offline   Reply With Quote
Old 12-04-2019, 09:44 PM   #2
dino2012ls3
Drives: 2012 ls3
My rear end shop supplied mineral base GL5 85W140 fluid to go back in rear end and told me do couple warm up and cool down trips. No hot rodding obviously. Like run get the groceries and back home type drive.
dino2012ls3 is offline   Reply With Quote
Old 12-05-2019, 07:24 PM   #3
IWANTA(ss)
IWANTA(ss)'s Avatar
I got some advance auto brand fluid for the break in I’m gonna go with the Lucas in 500 miles when I change it. What gears do you have and how do you like the true trac?
05 ZX-10
13 1LE
14 Nightrod Special
Old 12-09-2019, 09:45 AM   #4
dino2012ls3
Drives: 2012 ls3
I have Motive 410s with the Tru Trac. Haven't really been able to get on it since I did my clutch at the same time. But from what I've felt so far absolutely love them. It seems to really put me in my cam's power band fast.
Old 12-09-2019, 10:49 AM   #5
zlathim
zlathim's Avatar
Drives: 2010 Camaro 2SS/RS M6
My advice is to stay away from prolonged highway speeds for the first 500 miles. It is also a good idea to invest in an infrared temp gun and make sure the diff doesn't get over 180* F during the break in period.
GPI SS2; EE E2 catch can; SP 1 7/8" LT Headers w/ hfc; FM AT 3" cat-back; CAI Cold Air Intake; AEM Wideband
Tuned by GPI
McCleod RXT; MGW flat stick; Ram Clutch slave cylinder & hydraulic adjuster
BMR cradle & diff bushings, trailing arms, toe rods & upper control arm bushings
Hotchkis sub-frame brace
Stop Tech Z-23 brakes
4.10 gears, Eaton Truetrac, LPW diff cover
Best 1/4 mile 12.073 @ 115.68 mph 3,300 ft DA
zlathim is offline   Reply With Quote
Old 12-09-2019, 12:24 PM   #6
IWANTA(ss)
IWANTA(ss)'s Avatar
I have the stock 3.91 I wonder is there going to be that noticeable of a jump for me. I just her to pick up about 500 rpm sooner
So no 60-70 mph for more than 20 miles and keep it under 180* for the break in.
05 ZX-10
13 1LE
14 Nightrod Special
Old 12-09-2019, 02:29 PM   #7
zlathim
zlathim's Avatar
I was told to avoid highway speeds completely for the first 500 miles. That might be overly cautious, but mods like these are expensive and I tend to err on the side of caution. It sucked taking the back roads to work instead of the interstate, but that's what I did.
Tuned by GPI
Old 12-09-2019, 07:40 PM   #8
IWANTA(ss)
IWANTA(ss)'s Avatar
Ok yea I’m with better to play on the side of caution. She not DD anymore so I just take on a couple laps down the road and back when I get the diff in hopefully tomorrow
05 ZX-10
13 1LE
14 Nightrod Special
Old 02-01-2020, 09:36 AM   #9
IWANTA(ss)
IWANTA(ss)'s Avatar
100 mile update.
A-So it’s loud I don’t know if it’s the gears or the poly bushings and the lpw cover but it whines something fierce.
Will that go away after break in?
B-With the slow 40-55 mph hits I’ve done in 4 th gear I feel like the power gets there a wee bit faster and the car feels like it’s digging into the rear lifting up the front more.
Is that the tru track working it’s magic?
Overall can not wait till the break in is over to go WOT and do some launch’s to really see the difference.
05 ZX-10
13 1LE
14 Nightrod Special
Old 02-01-2020, 10:18 AM   #10
alice
alice's Avatar
Drives: 2010 camaro limited edition turbo
If it whines as bad as you say it is, the whine is not going to get any better. The set up is probably the issue. I've set up rear gears all my life and gear noise is most always caused by improper pinion depth. The poly bushings amplify the noise for sure but is not the primary cause. I have 5:36 gears with 30.5" tall tires in my Camaro and though some gear noise is expected as you go up in numerical ratios, even with ratios as high as mine, I only have a small, acceptable amount. For sure, the poly bushings had to go because I hate noise.
The best lube for reduced noise levels is the Lucas brand. That is my experience. Your 3.91/4.10 gears should make little to no noise especially if you go back to stock bushings. Your noise will not wear in or go away until the gears are properly adjusted. Won't hurt anything but certainly is aggravating. As far as noticeable increase in acceleration, it will be a small amount. Usually, to notice a real seat of the pants improvement, you need to increase ratios in increments of .3-.4. But you should notice a difference. Have fun!
alice is offline   Reply With Quote
Old 02-01-2020, 04:51 PM   #11
IWANTA(ss)
IWANTA(ss)'s Avatar
I may be over exaggerating the noise I’m going to switch to the Lucas fluid whenever I make it a third of the way through the breaking so about 166 miles see if that helps.
05 ZX-10
13 1LE
14 Nightrod Special
Old 02-01-2020, 05:57 PM   #12
gunchamp
gunchamp's Avatar
Drives: 15 Camaro SS
If you dont mind me asking, what was the price from gpi? Thanks
gunchamp is offline   Reply With Quote
Old 02-01-2020, 06:29 PM   #13
bkevind
bkevind's Avatar
Drives: 2013 2SS RS 1LE
Man I had Yukon 410 put in with my Truetrac of my 1LE. It was unbearably loud and never got any better.
I also had LPW cover, upgraded diff bushings, and the solid cradle bushings put in at the same time.
One issue is that whatever whine the diff is making will be greatly amplified by the solid bushings.
The noise wasn't so bad on the track, but driving to and from the track was unbearable.
Long story short I've got the GM 3.91 going back in with the Truetrac and hope it's a decent bit quieter.
The diff shop had a hell of a time taking the diff apart, they had to fab up a tool to get it open. So the original install was probably at fault, and maybe defective Yukon gear set.
468, Mishimoto rad + oil cooler, TSP LTH
MCS 2WNR
CTSV/ZL1 front calipers/rotors + G-Loc
Forgestar CF-5 19x11
bkevind is offline   Reply With Quote
Old 02-01-2020, 10:29 PM   #14
Pro-tuned
Angewendet Ingenieur
Pro-tuned's Avatar
Drives: 14 Camaro ZL1
I have full “polyurethane” BMR including cradle and diff bushings along with Tru-track and 3:45s no issue since installation 12,000 miles now. If I had to guess the issue I would say improper gear alignment...
LQ9, Iron Block, Forged internals, 408CI, Jannetty custom cam, TS short block, Whipple, Hardened Jackshaft, PRC 260, 2X3 Dynatech Full Competition, HF Cats, CAI, NW 103, Chee, ID 1300, COPO Breather, MSD, Fore Dual Pump, ultratorque, E85, dual Meth, True Trac, 3:45, 1500hp axle-shafts, DSS CF, BMR, custom Pearl/Candy paint by Jaidah.
Pro-tuned is offline   Reply With Quote
