05-03-2012, 02:58 AM | #239 | |
Drives: 2SS 2010 Camaro, 2007 Acura TL Join Date: Mar 2009
05-11-2012, 06:28 PM | #240 |
GM Has a fix for the rear axle chatter
Document ID: 2672507
#PI0137B: Rear Axle Chatter Type Noise on Low Speed Turns The condition may be caused by a slip/stick of the posi-traction clutch plates. As the plates slip and stick, a jumping or jerking feel occurs, accompanied by a chatter noise. The fix is replacing the Synthetic Differential Lubricant (P/N 89021677) and adding a Lubricant additive (P/N 1052358). These are US only P/N. It's covered under warranty and it worked for me. |
05-12-2012, 08:55 AM | #241 | |
Drives: IOM V6 RS 38808 Join Date: Jan 2007
I've known how to spell Camaro since before you were born.
05-12-2012, 06:15 PM | #242 |
Drives: 2012 ZL1 - #670 Join Date: Jun 2009
The problems and fixes in this thread are for the SS, if you're driving the LT I don't think it will help your problem and you probably have something else going on.
05-12-2012, 06:37 PM | #243 |
feel so sorry for you guys i'm disgusted about all this. new cars having problems..gm should have let the straight axle diff under instead of going with a new piece for making a independant suspension. or better yet put in place a better quality part and more durable more heavy duty..
my 2002 ws6 trans am ,with it's straight axle had no issues in 10 years -85000miles- it rides like a truck but at least it's not making any noises.. i hope the new models of diff will be corrected and problems adressed for them to be once and for all reliable for all the new customers..including me in the future.. |
05-18-2012, 04:05 PM | #244 |
Drives: 2011 Camaro LS Join Date: May 2012
I have the same problem with my 2011. First time was at 4000 miles, they put additive in and 3 months latter groaning noise came back. Took it again and they replaced the fluid and all the seals. I get it back tomorrow (they shorted out the anti lock brake sensor and I had to wait a day for the parts for that). I hope this works, that noise is terrible when turning and backing up. At least its all under warrenty, just hate not having my car
05-22-2012, 07:13 AM | #245 | |
Drives: GM Vehicles Join Date: Jun 2010
Brandon Chevrolet Customer Service |
05-28-2012, 12:35 PM | #246 |
Drives: 2012 1SS Join Date: May 2011
I just noticed this for the first time this morning on my 2012 ss with 400 miles on it. It was a very nasty noise. I had just washed my car last night. I was backing into my spot at work. I had the wheel turned to the left and gave it just enough gas to back up and as I pushed the clutch in heard and felt a grinding noise. to me it felt like something with the brakes. now I am going to be paranoid about driving. does anyone know what the cause is after three freaking years?
05-29-2012, 11:40 AM | #247 | |
05-29-2012, 07:25 PM | #248 |
I took mine to the dealer yesterday and they didn't hear the noise because it was really warm. They did the software update for the ABS since I hear it more often in reverse than in forward gears but I heard the sound again this morning. The diff additive solved it temporarily last year and the first year I owned it so I'll have to wait for a nice cool day and see if it's pronounced enough to get one more additive before the warrantee expires. :-[
05-31-2012, 02:45 AM | #249 | |
06-01-2012, 03:56 AM | #250 |
Drives: 2010 camaro Join Date: May 2012
OK so why docent gm send out letters to customers about the problem......
06-01-2012, 05:19 PM | #251 |
SoCal HT5
I can hear a noise when the car is cold and I' wondering if it is due to the change in the differential fluid, I changed the fluid to royal purple and about a week after I started to hear the noise, I changed it again using the same royal purple and the noise still there, anybody went back to the dealer's fluid and that solve the issue? please let me know thanks. by the way I'm planning to change it back to the gm fluid and see if that takes care of the problem, will keep you posted.
06-01-2012, 05:42 PM | #252 |
Just Because!
Drives: 2010 SIM 2SSRS Join Date: Jun 2010
I did Rp and had the noise worse. Changed to mobile1 and GM additive. Problem gone for over 20k miles now. Gonna change again soon just cause.
