03-31-2013, 07:17 PM | #1 |
Drives: 2010 Camaro Join Date: Dec 2009
Installing a ACS T5 Splitter on a 2010-2013 Camaro RS LS LT Pn 33-4-101
Below are the steps involved to installing a ACS T5 Splitter from acscomposite.com
Estimated installation time is 15-45 minutes depending if the car is on a lift or ramps. Feel free to PM us with any questions. |
03-31-2013, 08:39 PM | #2 |
Drives: 2010 Camaro 2LT VR/RS CGM Rally's Join Date: May 2009
love this splitter!
03-31-2013, 09:02 PM | #3 |
"Camaro Joe"
t4 /t5 splitter from acs is the best camaro splitter on the market, with the amount of abuse i have given to my splitter it should be in pieces scattered amongst the floor but instead it is in amazing condition with out 1 crack chip or broken part, the most damage on the splitter is a little scratch of paint
03-31-2013, 09:05 PM | #4 | |
Thank you for the feedback, ACS spends a lot of time in the R&D department, everything we learn with our OEM work we carry over to the aftermarket...
Our products represent 30 years of composite knowledge and design. Thank you for trusting us. Feel free to share photos of your installs ! Quote:
04-01-2013, 12:32 PM | #5 |
Drives: Silver 1LT 2011 camaro Join Date: Jul 2011
Installed this last night and the only confusing part is step 8 and 9. 8 Says to put a pressure clip in the center hole you drill but 9 says to put a bolt in it. Figured it was a pressure clip since there were 11 pressure clips and 11 holes drilled but it went on perfectly and I love the look!
Edit: just realized I posted in the wrong one I have the T4 Splitter but the instructions do seem the same.
04-01-2013, 03:29 PM | #6 |
Drives: 2014 Z/28 #82+#192, 18ZLE 66Nova Join Date: Oct 2008
I was at a club meet this Saturday, Member had this on his car, let me say this, the front looked 100X better with this on then before.
04-04-2013, 12:26 PM | #7 |
This wont work on a SS/RS???
04-04-2013, 12:30 PM | #8 |
The T5 is for V6 here's the one you'll need http://www.camaro5.com/forums/showthread.php?t=260932
07-12-2013, 09:09 AM | #9 |
Drives: ELLE-1 Join Date: Jul 2011
sub
07-23-2013, 03:37 PM | #10 |
NewDivide
Drives: SW '13 1SS/RS & '12 Honda CRV Join Date: Jan 2011
I just bought this splitter but recv'd only bolts/nuts, not the push pins described above. Has there been a change in the install process? How can the nuts/bolts be installed w/o removing the fascia?
08-10-2013, 01:55 AM | #11 |
Drives: 2013 2LT Camaro Coupe RS Join Date: Jul 2013
IF I install this, what's the distance between the new splitter and the floor? Is it more likely to get it scratched or damaged due to being it lower to the cement?
08-10-2013, 08:26 AM | #12 |
Drives: 2012 SIM 2LT/1970 Camaro Join Date: Nov 2012
ACS states that it doesn't lower the ride height at all, so apparently that is the same. However, it will definitely change your "approach angle" clearance, as the car's chin will jut out further in front of the front wheels, so entering uphill driveways, parking ramps, etc, may cause problems or require you to approach slowly/diagonally to avoid nailing the splitter.
All bleeding stops eventually -- 2012 2LT Auto w/sunroof -- My journal thread
Roto-Fab Intake & W/W Relocate Kit -- ADM Race Scoop -- Dynomax VT Axle-Back Exhaust -- Vitesse Throttle Controller RX Catch Can -- Drake Bowtie Delete -- JacFab Radio Face Cover -- LED Fog Lights -- LED Dome/Trunk/Plate Lights -- Gen5DIY Dash ABL -- Diode Dynamics Cupholder Lighting Wishlist: ACS T5 Splitter -- Hood Vent Mod -- Footwell/Door Pull/Homelink Button Lighting |
08-10-2013, 08:30 AM | #13 | |
Correct, it wont lower the ride height, however, it will make your car longer...
A small compromise consider the effect ;-) when in doubt simply approach steep slopes at an angle. I have driven the T5 Splitter donw extremely steep underground driveways with no rubbing... and this is also with a lowered car. Quote:
08-12-2013, 10:38 AM | #14 |
I just got the T5 and had the dealer install with the bolts...took him about an hour to do cost me 45 $$ and i love it..i was really paranoid about front splitter hitting the ground but no worries with the t-5 AT ALL!!!!!
acs composite, camaro v6 spoiler, t5 splitter |
