06-16-2023, 03:30 PM | #29 | |
Having FUN in the SUN...
Haha... I'm sure your right
06-16-2023, 03:31 PM | #30 | |
Will your solution be a drop in, or external pump?
06-16-2023, 09:14 PM | #31 | |
Drives: 2016 Camaro SS 2017 Yukon Denali Join Date: Jan 2020
Any plans for a similar product for a 2017 Yukon? |
06-19-2023, 09:33 AM | #32 |
06-19-2023, 08:05 PM | #33 |
Drives: 2020 SS Camaro A10 Join Date: Jan 2019
SMG Big Boy Fuel Pump
I have one in my bolt-on ZL1, no cam or lash cap, had plenty of room to run full E85, they work, put down a conservative 650 whp, cam and ported blower next
06-23-2023, 11:41 AM | #34 |
Drives: 2019 zl1 6 speed Join Date: Jul 2017
So do you guys recommend the jms, fuel pump, or both to tune on e85?
07-22-2023, 11:15 PM | #35 | |
Awesome... how long have you been running it? any issues? Did you install yourself?
07-23-2023, 01:55 AM | #36 |
Drives: 2018 Hyper Blue ZL1 1LE Join Date: Dec 2018
Lack of a fueling solution like this is the main reason I would not attempt to significantly modify my 2018 ZLE. You can add all the power mods you want, but without highly reliable fueling to support it under 1/2 tank and high G conditions on a road course, you're driving a ticking time-bomb. The BigBoy seems better than others, but according to Katech it doesn't provide the surge tank capabilities of the stock bucket because it loses its seal.
If you track your ZL1 you need this capability for high G turns or you will blow your motor due to dangerous lean AFR from fuel starvation. This is a must for anyone tracking their ZL1, and it looks like the Katech solution resolves this issue. The best solution for track use is a fuel cell with high capacity racing pumps and a built in surge tank, but this requires you to go full race car and lose streetability. |
07-23-2023, 11:41 AM | #37 |
Sounds like a good time to poke Katech again on a ETA for their drop in solution?
08-11-2023, 08:00 AM | #38 |
Just wanted to update that a Friend of mine had this SMG pump installed on his 2016 SS.
Mods: Rods/Pistons 377 (10.7:1) Ported heads BTR stage 2 centri cam with 38% lobe LPE HPFP +30 FIC injectors P1x stage 2 with 8" lower 3.9 upper(12psi) Based on the logs this setup is trying to make around 800-820whp. On E50 this low side pump will not hold pressure above 6200rpm. It drops like a rock down into the 30's and rail pressure tanks. I tried SMG's suggested pump settings and everything in-between. If we turn the JMS voltage booster on, then the pump holds pressure perfectly, but this pump does not like the voltage booster. It causes the FSCM to throw insufficient fuel codes which never happened with the LT4 low side pump. The fact that the pump will hold commanded pressure with a JMS tells me that it simply isn't capable of keeping at normal drive voltage. So, it's not an issue with the FPR bypassing excess pressure. Anybody out there that has made one of these work on a 800whp + build running E50+ I am all ears!!
2016 NFG 1SS A8
08-11-2023, 09:07 AM | #39 | |
Drives: LS powered Join Date: Jun 2016
08-11-2023, 09:59 AM | #40 |
Drives: 14 Camaro SS 1LE Join Date: Feb 2019
08-11-2023, 10:06 AM | #41 |
According to the website it's supposed to be able to feed "real power". This size pump feeds Hellcats making 900whp on E85 at much fatter AFR's. I don't think very many have run this pump because it hasn't been out very long for gen 5 LT stuff, nor has it been proven. But I appreciate all the help you have provided!!
2016 NFG 1SS A8
08-11-2023, 10:25 AM | #42 |
Drives: Chevrolet Camaro Join Date: Apr 2022
Reading the reviews they are saying you must follow their tuning setup for the pump. Did you check out the sample file? https://cdn.shopify.com/s/files/1/07...t?v=1684499180
Procharger P1X, CSP Big Boy Cam, CSP Headers, LT4 HPFP, LT4 Injectors, JMS BAP - 722WHP
