01-21-2020, 02:55 PM | #1 |
Drives: 2016 Camaro 2SS Join Date: Oct 2016
Question about Costly Repair
Hey all!
I daily drive a 2016 Camaro 2SS that has just over 62,000 miles. Recently I have noticed that engine oil is leaking in my driveway. After taking the car to a Chevy dealership, they let me know that the oil pan gasket is leaking. They said that while the gasket is cheap, the labor cost for repair would be just under $2,000. Is this a fair price? I was told the engine would have to be removed from the car to access the repair. My first thought was to use ATP AT-205 Reseal, but according to my service guy the oil pan gasket isn't rubber but instead a type of silicone liquid of types. Is this true? Thanks in advance to any help! |
01-21-2020, 03:06 PM | #2 |
That is completely out of line. You can unbolt the motor mounts, lower the cradle and raise the motor enough to get the pan off. I'm pretty sure a competent mechanic could replace the pan in a fairly leisurely 8 - 10 hours.
Baby Blue
01-21-2020, 03:50 PM | #3 |
Drives: 2017 2SS / 2003 S10 Crew Cab Join Date: Oct 2019
It would be worth your time to get another opinion either at another dealership or independent shop. Gasket technology is much better now; they usually don't just fail on their own without an underlying cause.
Never say never! |
01-21-2020, 03:59 PM | #4 |
Drives: 2021 Camaro SS 1LE Join Date: May 2009
YIKES.......they are way overcharging you.......
2021 Camaro 1SS 1LE - Red Hot
2015 Camaro Z/28 - Red Hot 2001 Mecham Trans Am #3 - 7.0L LS1 |
01-21-2020, 04:09 PM | #5 |
Drives: 2016 2SS M6 Mosaic Blk Met-SOLD Join Date: Jun 2016
Repairpal.com says labor should be around $415.
Official Detailer of CamaroFest 8 & 9
https://www.autogeekonline.net/forum...st-8-pics.html https://www.camaro6.com/forums/showt...=521655&page=1 https://www.camaro6.com/forums/showt...=547470&page=1 https://www.camaro6.com/forums/showthread.php?t=527474 No one on Earth has detailed more Camaros. http://KirkTheDetailer.com |
01-21-2020, 04:58 PM | #6 |
Drives: A few Join Date: Oct 2017
Not if it's an 8-10 hour job as another poster said.
I never bothered to look to see how much would it would be to replace the pan on one of these though so not sure if that 8-10 hours is accurate.
-Dave
HPDE/DD: 2018 Camaro ZL1 1LE || HPDE/DD: 2015 Subaru BRZ ||Tow Vehicle: 2004 GMC Sierra 2500 8.1L || Weekend toy: 1994 MR2 Turbo || The other weekend toy: 1993 MR2 Turbo || Track car: 1998 Integra Type-R || Race car: 1996 Integra GS-R || New race car build: 1992 Honda Civic Hatchback Too many cars.. never. |
01-21-2020, 05:03 PM | #7 | |
Forgive my ignorance, but what kind of underlying issue would cause the oil pan gasket to leak? The service rep at the dealership had the attitude that this was a fairly common thing to have happen over time. Thanks again! |
01-21-2020, 07:05 PM | #8 | |
Never say never! |
01-21-2020, 08:14 PM | #9 |
Drives: 2017 2SS M6 Join Date: Jun 2013
there is no gasket. they use gasket maker RTV. if it is the oil pan its leaked because the bolts were improperly torqued or sealer was improperly applied or a defective oil pan. All are manufacturers defect . 2 thousand miles over warranty. a good dealer would take care of it.
01-21-2020, 08:51 PM | #10 |
Drives: 2024 Riverside Blue 2SS 1LE Join Date: Mar 2016
First thing I would do is get under the car use brake cleaner and get all the oil residue cleaned up. Then I would drive the car for a week and get back under and trace it down. I would not trust the dealer if they didn't take the time to clean it up, could be anything and might be a simple fix. Find it hard to believe the pan is leaking at 60k miles. I have a 2016 LGX and not a drop, 2006 GP with 130k not a drop. then again my 2005 2500HD does have a leak but its not worth doing the rear seal (major pain).
01-21-2020, 10:12 PM | #11 |
Who Needs to KNOW?
May be RMS and not pan gasket.
Start w good degreaser / power wash and once dry, corn starch the problem area - oil clings to corn starch and leaves you a nice, easy to follow trail.
ing for grip.
01-21-2020, 11:49 PM | #12 |
Drives: 2018 Camaro SS 1LE Join Date: Oct 2018
I believe there was a TSB on this. There was an issue with the factory bolts not properly tightened down. Either way, looks like its about a 400-500 job. Your dealership is trying to take advantage of you becuase either they are greedy, or Incompetent. Either way, take it elsewhere...
01-22-2020, 07:26 AM | #13 |
Drives: Former 2016 Camaro 1LT Join Date: Jan 2017
Dealerships will always charge the most for any repair. As already stated, best to find a good shop with good reviews and get them to do the work.
2006 C6 Corvette Manual, 2019 Silverado, 1997 Jeep Wrangler
01-22-2020, 08:23 AM | #14 | |
-Dave
