11-30-2011, 09:27 PM | #15 |
Learning from my mistake...do not disconnect the battery whatsoever if you have subs in the trunk. By disconnecting the battery you make it damn near impossible to open the trunk unless you fold down the back seat and pull the trunk release. Now again, make sure you don't have subs because if you do...you won't be able to reach the trunk release and instead you will nead another battery to hook your camaro up to open the trunk.
Just get a battery tender/trickle charger and hook it up to the spots under the hood as if you were going to jump start it and leave the battery hooked up in the trunk.
2011 Camaro 2SS/RS, Circle D 3200, ADM Transmission Cooler, BTR Valvetrain, Cam Motion .621 .595 228/244 113+4, ARH 1 7/8 full exhaust, Cold Air Inductions, Katech C5R TC, Melling HV, BTR SLR lifters, Trunion Upgrade, LS2 Dampner, LS9 head gaskets, Bo White PTB, MM can, GFX, Subs, B&M Deep transmission pan,
Holley fuel rail, Proform valve covers, relocated coil packs |
Similar Threads | ||||
Ginger gets a Braille light weight race battery! | SUX2BU | 5th Gen Camaro SS LS LT General Discussions | 84 | 10-31-2018 11:30 AM |
Battery Disconnect For Cold Air Induction ? | Tony's Jewel | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 8 | 07-17-2011 12:01 PM |
Regarding battery location | route66dan | 5th Gen Camaro SS LS LT General Discussions | 4 | 09-14-2010 09:29 AM |
Battery question | armando416 | 5th Gen Camaro SS LS LT General Discussions | 2 | 01-02-2010 07:06 PM |
LS3: fuse pull or battery disconnect?? | g-townmach | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 9 | 12-28-2009 08:31 PM |
