Vararam
Old 04-06-2021, 05:39 PM   #1
joekono
joekono's Avatar
Drives: Camaro Convertible 2014 1LT
Clicking sound
Before I rip my console apart(started, then stopped). I'm sure one of you could steer me in the right direction. I've been driving the car regularly since it's been nice out for a couple of weeks. Anyway, it's an automatic(I know, BOOOOOOOOOOOO) and today I turned the car on and every time I put my foot on the brake, I could hear a clicking(sounds like a relay) sound. I took the car out for a short drive with no issues. The car only makes this noise in PARK, any other gear, no click. I've never heard noise before and it's coming from right under the shift knob. Thanks and I will wait for the next command.
joekono is offline   Reply With Quote
Old 04-06-2021, 05:59 PM   #2
AlanRubin
Drives: 2010 LS
Originally Posted by G8One2 View Post
Its the solenoid that lets you take it out of park. Completely normal. May be a little worn, so that its making more noise than usual. But if it wasnt making any noise and not working, you'd be stuck in park until it was fixed.
Incorrect, there is a manual release so you do NOT get stuck.
Procedure is in the owners manual!
AlanRubin is offline   Reply With Quote
Old 04-06-2021, 06:18 PM   #3
redcoats1976
theres also a thread in here that will show you how to disable this feature by disconnecting a plug in the steering column.had the solenoid and shifter replaced under warranty.when they wanted 400 bucks to do it again the next year out of warranty i unplugged it.look up "cant get key out of car"
Old 04-06-2021, 06:39 PM   #4
joekono
joekono's Avatar
Thanks for the replies. Yeah, it does sound like a loud solenoid but it's interesting in the manual about the "shift lock release" which isn't my problem but this is good to know if your battery is running low. I'll keep taking ideas but the car it running fine and if it's the shifter like redcoats1976 says, I'll try to check the "car key issue". Keep any idaes coming because I'm going to let it sleep for the night. If there are any changes, I know it's electrical most likely. Thanks guys.
Old 04-06-2021, 07:39 PM   #5
joekono
joekono's Avatar
Well, had the whole shifter out and other than a loud solenoid(which is usually a good sign), the car seems fine. I guess I'll have to put up with that clicking sound when I get out of park. Thanks guys for the help.
Old 04-07-2021, 12:08 AM   #6
AlanRubin
Drives: 2010 LS
Not the point.....
WRONG, you said;
WRONG! He would not be STUCK till it was fixed; EXACTLY the point.
The procedure is in the owners manual so YOU WILL NOT BE STUCK UNTIL IT'S FIXED.
Your fault you don't know the car, not mime, not his...
Old 04-07-2021, 07:44 AM   #7
CamaroCracka
CamaroCracka's Avatar
Drives: 2010 Turbo LS3
And six cylinders suck!
Old 04-07-2021, 07:48 AM   #8
Roamer63
Roamer63's Avatar
Drives: 2014 camaro 2ss/rs
Mine has always done the same thing. No problems
Roamer63 is offline   Reply With Quote
Old 04-07-2021, 09:51 AM   #9
redcoats1976
and this has what to do with the subject of this thread?
Old 04-07-2021, 10:06 AM   #10
joekono
joekono's Avatar
Thanks redcoats1976. There's a lot I could say here but I love my car the way it is. There's always a few of them on every forum. Anyway, went back to the car and saw exactly what you were talking about with the ignition wire. The brake being in park and getting the key out all seem to be connected. Thanks again man for everything.
Old 04-07-2021, 10:41 AM   #11
CamaroCracka
Oh, I thought we were getting into an argument, so I figured I would poke the bear. I don't really have anything against 6cyl.
Old 04-07-2021, 02:05 PM   #12
redcoats1976
we did have an entertaining thread on that subject like a year ago.gringo,rontammy and about half the forum members duked it out...LOL
Old 04-07-2021, 02:37 PM   #13
CamaroCracka
I know, I miss Ron's videos.
Old 04-07-2021, 06:53 PM   #14
romcjr
romcjr's Avatar
Drives: Two 1984 Z28 / 2014 2SS/RS AGM L99
I did that to mine as well because I had key removal issues the first week I had the car .
romcjr is offline   Reply With Quote
