TireRack
Old 09-08-2020, 03:59 PM   #1
joekono
joekono's Avatar
Drives: Camaro Convertible 2014 1LT
Help with Part Number
Hey everyone, I was hoping that I can get a confirmation on a GM part number. I just ordered the catch can from Elite Engineering and want to order the tube that I will have to cut(the one that goes from the throttle to the pvc valve) just so I have it on hand(OCD) I already have the K&N CAI installed and that was just a matter of keeping the stock intake parts. The tube is the one that has already been split to go into the catch can as you can see. Thanks for your help as always.
joekono is offline   Reply With Quote
Old 09-08-2020, 04:14 PM   #2
mikeman
Drives: 2015 Camaro
I'd lose the breather on the oil cap. Not good. Get the clean-side separator cap from Elite.
mikeman is offline   Reply With Quote
Old 09-08-2020, 04:29 PM   #3
joekono
joekono's Avatar
Oh no, this isn't my car, I was just showing what tube I was referring to. Yeah , I'm thinking about doing the clean side separator cap from them too.
Old 09-14-2020, 04:31 PM   #4
joekono
joekono's Avatar
Bump. Just wondering because I can't find the part number anywhere. Even called the dealer and they weren't much help.
Old 09-14-2020, 06:58 PM   #5
KillboyPowerhead
Drives: 2015 Z/22
https://www.camaro5.com/forums/showthread.php?t=511082
Overkill/Self Tuned; Mace Camshafts; K&N Typhoon Cold Air Intake; Ported 80mm Throttle Body/Intake Manifolds/Manifold Spacer; Solo Performance High-Flow Cats, Cat-back Exhaust; Vitesse Motorsports Throttle Controller; Elite Engineering E2 Catch Can; BC Racing BR Coilovers; JPSS Delrin Radius Rod Bushing Inserts, Sway Bars; Pegasus Aluminum Rear Cradle Bushings, Camber/Caster Plates; Z/28 Toe Links, Trailing Arms, Upper Control Arm Bushings, Rear Shock Mounts
KillboyPowerhead is offline   Reply With Quote
Old 09-15-2020, 01:21 AM   #6
joekono
joekono's Avatar
Originally Posted by KillboyPowerhead View Post
KillboyPowerhead, you are the MAN!!! Thank you. Great website too.
