07-08-2020, 11:54 PM | #1 |
Drives: Camaro Convertible 2014 1LT Join Date: May 2019
Just checking.
I will be doing the CAI change to my Camaro this weekend or next(got the K & N one). I'm embarrassed to ask but I just wanted to make sure to ask if anything needs to be set or reset as far as the PCM goes because this is the first time I will be pulling the ground cable off the battery since I got the car last year. I do know the ground cable is in the trunk.
07-09-2020, 12:00 AM | #2 |
Drives: 2014 2SS/RS Join Date: Jan 2018
No. In fact I dont even disconnect the battery when just doing an intake but you may want to do the fuse pull to reset your fuel tables. Search "fuse pull"
2014 2SS/RS LS3/M6
07-09-2020, 07:38 AM | #3 |
Drives: 2012 Camaro SS Transformer Join Date: Sep 2013
I added a CAI brand kit on my 2012. Simple install, didnt disconnect battery, no issues.
Mods: trunk subwoofer and amp, LED lighting (fogs, interior, trunk), skip shift eliminator, CAI cold air kit, Vmax ported throttle body, Stainless Works retro chambered cat back, JBA Cat4ward SS ceramic coated headers Potential Next Mods: Tune, F&R sway bars, rear cradle bushing inserts and trailing arms |
07-09-2020, 10:46 PM | #4 |
Thanks. Some videos do state you don't have to disconnect so I won't and I'll look up "fuse pull". Thanks again.
