05-15-2022, 03:13 PM | #1 |
Having FUN in the SUN...
WEIRD DYNO GRAPH!!!
Hey guys… finally got some numbers on the DYNO to satisfy my questions after my JRE remote tune. Car made 655rwhp and 740rwtq but the graph looks strange. Any thoughts?
05-15-2022, 03:18 PM | #2 |
Maybe this will help?
05-15-2022, 03:24 PM | #3 |
Hey guys, just trying to make some sense of the data here that HP tuners is giving me. Does the supercharger inlet pressure of 13.5 psi equal my boost level?
05-15-2022, 03:25 PM | #4 |
Did they grab RPM from plug wire?
05-15-2022, 03:25 PM | #5 |
05-15-2022, 03:27 PM | #6 |
It was like 90+ degree outside… looks like my IAT was high?
What’s the diff. Between SAE and IAT 2? One is 86 and the other is 117 ?
05-15-2022, 03:42 PM | #7 |
Drives: 2019 Chevy Camaro ZL1 M6 Join Date: Jul 2019
I had almost the exact same setup as yours and made 650/673 SAE. Your torque reading looks really high to me.
Kong Stage X Port, NW103, LPE HPFP, XDI +30 Injectors, ARH Headers, Flex Fuel, JMS Booster, AWE Touring, Elite E2-X CC. Stock heads, stock cam, stock pulleys: Tuned by KingLT1. 740whp Uncorrected on e50
05-15-2022, 03:54 PM | #8 |
OK, i see what looks odd... that the graphs read different numbers on the left and right side, so the graph doesnt look even. Also, i see that the TQ had a weird spike... So i think i will take away that the car made 655/650 +/- for now... Send this to JRE for feedback also.
05-15-2022, 07:47 PM | #9 |
Few things:
Ignore the blip in beginning. Not a good reading on RPMs. Your car didnt make 700+ tq. It looks to be right around 650/650. in STD btw so subtract 3% for SAE readings, but it was hot so that's probably why they corrected STD. Ignore IAT2, its useless. You want to be looking at MAT and IAT1 temps. Your MAT temp here is 64C (147F) HOT but typical. IAT 1 is 86F (air entering intake) In your screenshot you show 168 KPA of pressure. The way to calculate boost is. MAP - barometric pressure. EX: At sea level you would take 168.8 - 101 (14.7lb sq in) = 67 67 KPA = 9.7PSI of boost. So take your highest KPA reading and subtract your barometric pressure and that is your boost in KPA. Then use any pressure calc to convert. Looks like your barometric pressure is 13.9 psi. (95KPA) so you subtract 168 - 95. (73) = 10.5lb boost. Its much easier if you change everything to KPA and F. Also raise the limits in the graphs, otherwise if anything is above your threshold you wont see the line graph. If you need help reading anything else just message me.
928rwhp - 93 | 1040rwhp/898rwrq - E65 SAE
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90 Last edited by Camaro1973; 05-15-2022 at 08:49 PM. |
05-16-2022, 01:37 AM | #10 | |
Drives: 22 ZL1 1LE A10 Join Date: Feb 2022
05-16-2022, 03:53 AM | #11 |
Drives: 2010 camaro Join Date: Dec 2017
torque is bit high. log is safe tho. enjoy!
05-16-2022, 07:00 AM | #12 |
Drives: HBM ZLE Join Date: Aug 2017
Where'd you end up getting it dynoed?
05-16-2022, 07:02 AM | #13 |
Thank you Al Oppenheiser!
05-16-2022, 08:25 AM | #14 | |
Thanks for the feedback.. i have alot to learn...
