Go Back   CAMARO6 > Engine | Drivetrain | Powertrain Technical Discussions > Tuning / Diagnostics
Old 04-14-2022, 06:57 PM   #1
SOCAL.M6.ZLE
Having FUN in the SUN...
SOCAL.M6.ZLE's Avatar
Drives: 2022 M6 ZL1 1LE
NEED HELP WITH CODES AFTER MODS…
Hey team… after installing the mods in my signature I am getting the following codes. The think they are from the flex link kit but not sure how to test or fix…any help would be appreciated.
TSP VVT and DoD Delete Covers + LME Chain Guide + DSX Billet Lid + ATI Damper + 9.17" Lower + 2.4" Upper + MM Wild CC
Coated ARH + AWE Touring + Magnaflow Center X + E85 + MSD Coils + Banks iDash + JMS Booster + Synergy Fender Tank
ALL the RED Rear End BMR Goodies + JRE Terminator Cam Package + Remote Tuning and Moral Support from TED @ JRE
BMR Motor Mounts + DMS Front HX + FIC 30's + APEX SM.10's + 305/345 R888R's = 770rwhp 785rwtq @E50 13.5psi
SOCAL.M6.ZLE is offline   Reply With Quote
Old 04-15-2022, 10:43 AM   #2
ctrlz
since you get 5 harnesses, I would make sure the right one was used:
Port 2 - Power-up Port
3 harnesses are used on the port 1 side – Harness #2, 4, 5
Harness 4: For GM LT and 6.2L Ecotech3 Engines, plugs directly into purge valve
connector
Harness 5: For GM LS Engines, plugs directly into purge valve connector
Harness 2: Output, power and ground for Stand Alone ECU
sounds like you need #4.
The codes sound like the purge circuit is getting no signal.
https://cdn.shopify.com/s/files/1/01...f?v=1594069931
