03-22-2022, 05:25 PM | #1 |
Having FUN in the SUN...
BEST CATCH CAN ????
I understand that the word BEST is subjective, so I'd like to clarify that im looking for a catch can that...
A: Prevents as much OIL from entering the blower as possible. B: Allows me to remove as MUCH of the ugly PVC system plumbing as possible. C: Is easy to install (don't want to lift the blower at the moment) Perhaps all can be achieved by one? or am I dreaming?
03-22-2022, 05:52 PM | #2 |
i have the elite catch can its one of the best ones out there!
03-22-2022, 11:12 PM | #3 | |
Coupe Newbie
Drives: 2017 ZL1, 2021 Corvette Convertible Join Date: Jul 2011
03-23-2022, 08:41 AM | #4 | |
'20 ZL1 1LE A10,
03-23-2022, 08:44 AM | #5 |
Mighty Mouse and Elite are the two most commonly used. This question has been discussed to death if you search the forums.
03-23-2022, 09:59 AM | #6 |
Drives: 2018 ZL-1 Join Date: Jan 2018
Elite. But you will have to lift the blower.
Their mounting bracket kind of sucks. I had mine tack welded underneath at the bolted joint you see in the picture, as I was concerned that it would twist a bit over time. |
03-23-2022, 02:07 PM | #7 |
Drives: 2019 ZL1 Riverside Join Date: Apr 2020
Mark - Elite sells a front mount bracket now, I moved the blower coolant reservoir to where you show the cc pictured
+1 on Elite - performance has been great |
03-23-2022, 02:20 PM | #8 |
03-23-2022, 02:20 PM | #9 |
Honestly the best style catch can that can accomplish 2 things is the best can. The Mighty Mouse wild does away with the pcv completely. It allows any excessive blow by pressure to be vented via top filter and then rest of use it performs like other cans. Catches oil and connects to vaccuum by throttle body.
Anyone running high boost should really have a way to blow off any excessive blow by pressure and the wild can does just that.
928rwhp - 93 | 1040rwhp/898rwrq - E65 SAE
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90 |
03-23-2022, 05:05 PM | #10 | |
Drives: 2018 Camaro ZL1 Join Date: Mar 2022
Would you happen to have the part number for the front mount bracket and a photo of your install? I asked Elite about one last month but the photo they provided showed the bracket mounted just under the throttle body and my 2018 ZL1 looks nothing like their photo. |
03-23-2022, 06:23 PM | #11 | ||
Elite does the same, but the flow restrictor is installed under the blower where it belongs
You have to call them for information on the front bracket, I can post a pic of my set-up if interested |
03-23-2022, 07:23 PM | #12 |
03-23-2022, 07:42 PM | #13 | |
This makes absolutely 0 sense. The flow is one way, there's nowhere for blowby gasses to go. Apparently you have no idea how a closed looped PCV system works. Nor does it have anything to do with warranty claims. Just keep riding your bike instead. No shop in their right mind is going to put a closed loop can on a 1000hp car with high boost.
03-23-2022, 08:04 PM | #14 | |
1130 crank HP here still running the stock LT1 crank seal. MM Wild FTW.
