Go Back   CAMARO6 > Engine | Drivetrain | Powertrain Technical Discussions > Tuning / Diagnostics
Old 03-14-2022, 05:03 PM   #1
SOCAL.M6.ZLE
Having FUN in the SUN...
SOCAL.M6.ZLE's Avatar
Drives: 2022 M6 ZL1 1LE
REMOTE vs. DYNO TUNING
Hey team, I am late to the remote tuning tech, and will soon need to make a decision on what to do with my car.
I am about to install a RotoFab, Soler 95mm TB, ARH full system + HF cats + AWE catback + Flexlink E85 kit + Colder NGK plugs, wires etc...
I have heard amazing things from JRE and others for remote tuning.
and wanted everyone's 2 cents on if remote tuning makes sense for the mods i have or should i wait to find a local dyno tuner...
Let the debate begin?
TSP VVT and DoD Delete Covers + LME Chain Guide + DSX Billet Lid + ATI Damper + 9.17" Lower + 2.4" Upper + MM Wild CC
Coated ARH + AWE Touring + Magnaflow Center X + E85 + MSD Coils + Banks iDash + JMS Booster + Synergy Fender Tank
ALL the RED Rear End BMR Goodies + JRE Terminator Cam Package + Remote Tuning and Moral Support from TED @ JRE
BMR Motor Mounts + DMS Front HX + FIC 30's + APEX SM.10's + 305/345 R888R's = 770rwhp 785rwtq @E50 13.5psi
SOCAL.M6.ZLE is offline   Reply With Quote
Old 03-14-2022, 05:36 PM   #2
Joshinator99
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Bolt on tuning is pretty straightforward no matter how you slice it. Nothing wrong with a street tune in your case.
Joshinator99 is online now   Reply With Quote
Old 03-14-2022, 09:55 PM   #3
cjperformance
cjperformance's Avatar
Drives: 2017 Camaro SS 50th Anniversary
Or... you could pick up a new skill?
2017 50th Anniversary Edition | P1X Stage 2
DSX Aux Low Side | LT4 high side | Flex Fuel
TooHighPsi Port Injection (installed & tuning)
CircleD 3K Stall | QA1 CF Driveshaft
Forgestar F14 Drag 17x10 NT555R2 305/45/17 Rear
Forgestar F14 18x8 NT555G2 235/50/18 Front
10.84@131 w/4.13" pulley
??.??@??? w/3.7" pulley (installed & tuning)
cjperformance is offline   Reply With Quote
Old 03-15-2022, 06:06 PM   #4
Trochoidal
I agree with CJ!
Originally Posted by arpad_m - “Aww, yet another oil thread with almost the same question in the OP“
Trochoidal is offline   Reply With Quote
Old 03-15-2022, 08:38 PM   #5
JSH
JSH's Avatar
Drives: '20 ZLE
You'll end up with a faster car if you tune it based on logs made from pulls on the road versus on a dyno.
'20 ZL1 1LE A10,
OEM short block, LME heads/valve train, E2650.
100+ octanes, no eth, no meth, no N2O.
2/23 - 1031/1004 wheel.
4/23 - 1.41/9.61/145 at DA 7000 ft. (only made five passes).
2/24 - LME 390, E2650, FBO, 100 oct.; 1116hp/ 1063tq; 109 oct. dyno next.
JSH is online now   Reply With Quote
Old 03-15-2022, 09:21 PM   #6
Puddin
Drives: 2016 Camaro 2SS
I don't know about faster but possibly better all around drivability sure.
Puddin is offline   Reply With Quote
Old 03-16-2022, 05:21 PM   #7
17camaroSS
17camaroSS's Avatar
Drives: Chevy Camaro SS
I personally like to do a dyno tune first then go to remote tuning to clean it up where it needs it, if it needs it.
2017 1SS:Hi-Ram, FBO, OTR ram air,
Circle D converter.
Previous PB: 11.07 @124 1/4
7.1 @100 1/8 1.6 60’ w/2” longtubes,
95mm hi-ram,
OTR ramair, flex fuel
17camaroSS is offline   Reply With Quote
Old 03-17-2022, 03:13 AM   #8
MakCamaro
Makis
MakCamaro's Avatar
Drives: 2020 Red Hot ZL1 A10
Initially I was planning to do a remote tuning, but then I found out that I absolutely need to use a wideband AFR gauge and this includes fitting the gauge itself inside the car and adding a bung to my exhaust pre-cat for the wideband O2 sensor. I am not going to need the gauge for my daily driving and I don't like the looks of having a gauge in my car. Therefore I decided to avoid all this unecessary hassle (and additional costs) and I will go with a local tuner.
Red Hot 2020 Camaro ZL1 A10 <-- Enjoying the hell out of it
Mosaic black 2018 Camaro 2SS A8 (sold)
MakCamaro is offline   Reply With Quote
Old 03-20-2022, 08:36 AM   #9
s346k
s346k's Avatar
Drives: like an old lady
i think: the more complex it is, the more important it is to be on a dyno. i think you will be fine with a remote tune. also consider, just because something is dyno tuned does not automatically mean it's going to run good.
my car was dyno tuned and then verified on the street afterward.
2016+ camaro: everyone’s first car
s346k is offline   Reply With Quote
Old 03-30-2022, 07:49 PM   #10
JANNETTYRACING
JANNETTYRACING's Avatar
The saying goes a Hammer does not make a carpenter.
Whether you dyno tune or street tune, it is the experience and attention to detail by the tuner that makes the difference.
I can get exacting results in either situation.
I used the exact same process whether the car is on the street or on the dyno.
In a production atmosphere I can do a lot more in a shorter amount of time on the dyno due to not dealing with traveling to a spot and traffic, finding a place to pull over to make changes.
Street tuning takes longer but the end results can be better in many cases just due to real situation tuning.
Ted.
www.jannettyracing.com
email tedj@jannettyracing.com
Old 03-30-2022, 07:50 PM   #11
JANNETTYRACING
Any tuner worth his salt will be welding a bung in your exhaust before the cat.
Ted.
Old 03-30-2022, 07:51 PM   #12
JANNETTYRACING
Proper tuning is done from Idle up, Not Full throttle down.
Ted.
Old 03-31-2022, 10:51 AM   #13
SOCAL.M6.ZLE
Ted.
Hey Ted... Looking forward to receiving the remote tuning kit and voltage booster you sent me last week... I just got the bung welded yesterday, and had the exhaust quieted down a bit while there... car sounds much better but still runs like crap. Cant wait to get it tuned
Old 03-31-2022, 11:08 AM   #14
JANNETTYRACING
Thank you for your business.
Looking forward to getting you fixed up.
Ted.
