04-21-2014, 11:12 PM | #1 |
Drives: 2011 Camaro 2Ss M6 Join Date: Dec 2011
Will 315/35/20's and 285/35/20's Not work?
I plan on purchasing 20x10 for the front and 20x11 in the rear. Will the tire sizes listed above not work with my 2011 2SS M6 camaro? I am worried the stability trac will freak out cause of the different height in the front and rear tires?
All advice and help is greatly appreciated!! Are you successfully running these tire sizes without any issues and which brand of tire are you running? |
04-21-2014, 11:19 PM | #2 |
SoCal Camaro5 Race Team
Drives: 2021 Shadow Grey Camaro 2SS 1LE Join Date: Mar 2010
. 8"difference could cause a problem.
04-21-2014, 11:25 PM | #3 |
Thats what I've been told by a fellow forum member. So which setup would suite me the best then? are the 20x10/20x11 not the right setup for me? Or should i just try and go with like a 275/40/20 and a 315/35/20? Im also worried about any kind of rubbing on the emergency break cable.. |
04-21-2014, 11:35 PM | #4 |
Originally Posted by Nighthawk89 Hey brother, which tire sizes did you go with and do you have any issues with the stability trac? Response 20x10 +23, 20x11 +43 285/35R20, 315/35R20 No issues @ all with anything MadGiggler |
