08-11-2022, 07:49 AM | #15 |
Petro-sexual
Why?
Did they talk about a release date?
08-11-2022, 04:06 PM | #16 |
Originally Posted by arpad_m - “Aww, yet another oil thread with almost the same question in the OP“ |
03-02-2023, 10:38 PM | #17 |
Drives: 2022 ZL1 M6 Join Date: Mar 2022
Anyone know if this has been resolved by Banks because according to this:
https://docs.bankspower.com/bids/fil...2L_V_76_E.html the 6th gen Camaro should have a wideband sensor that can directly communicate with an iDash without using an AEM to piggyback. However, when I go to their "Sensors and Beyond" tab I do not see any such Wideband O2 sensor kit?
2022 Black ZL1 M6
RF intake, Soler TB & TC, ADM v2 reservoir, AWE Touring non-resonated catback exhaust. 535 whp, 537 tq. SAE Smoothing: 5. DynoJet. No tune. 91 octane. |
03-03-2023, 07:06 AM | #18 | |
The OEM O2 sensors are narrowband only and cannot tell anything beyond rich/lean of stoichiometric. You need the AEM or equivalent to run a wideband.
05-13-2023, 02:41 AM | #19 | |
Drives: ATS 2.0t Rwd Performance Join Date: Jun 2017
I really hate that these don't show Kr though. Makes me want to find an Ngauge. |
05-13-2023, 10:52 AM | #20 | |
Lack of KR and PW is a letdown. I do like the Banks iDash too much to get rid of it now. If I ever go FI I may change it out. But I can get all of that data from HPT, just not a convenient as a mounted gauge. Here’s an example of fused adapter. https://www.amazon.com/Roadpro-Repla...15137789&psc=1
05-13-2023, 11:30 AM | #21 |
fo'shizZL1
Drives: 2017 ZL1 Join Date: Aug 2017
On two cars, I just put the AEM gauge in the glove box with a cheap Amazon pod and VHB tape. I never look at the gauge- I just log it in HPT. The neat solution is to buy a 30-0310 (no gauge), and have it reflashed to 30-0334 software so it can still be on the obd2 canbus. I've always wanted to do that but figured it was less hassle to just stick the gauge in the glove box.
2017 ZL1 M6 Black | Maggie 2650 // 103TB // Big Gulp
Past Rides- 2014 ZL1 M6 Red Hot | Tons of mods 2004 CTS-V M6 Silver | Many mods 1995 Corvette M6 Torch Red | A few more mods 1992 Camaro M5 White | A few mods |
05-13-2023, 02:07 PM | #22 |
Drives: 2019 Summit White ZL1 Join Date: Mar 2020
Sorry to go off topic a little but where are you guys running the wideband cable thru the firewall to the cabin?
05-13-2023, 08:29 PM | #23 | |
Having FUN in the SUN...
I believe it’s used as a sound tube on the SS models, it’s blocked off on the ZL1 so you have to drill a hole. It’s very easy to access
05-13-2023, 09:47 PM | #24 |
Awesome..thanks! I am in the process of installing a Banks I Dash and a AEM wideband with the ZZ Performance Gauge pod. Going to use the IDash to monitor E Content. But If some knows of a way to ditch the AEM wideband I am on board!
05-14-2023, 08:14 AM | #25 |
Drives: 2021 Camaro ZL1 Join Date: Mar 2023
I ran through the grommet that is inside the drivers side fender, right next to the door, below the A-pillar. It was very easy to access and run the wiring.
2021 Camaro ZL1 Satin Steel Metallic
Rotofab CAI, Banks Idash, AEM X series wideband, CSP 2" headers, Jet hot 2500 ceramic coating, DSX Flex Fuel Sensor, DMS Fender Tank, Velossatech Big Mouth, JMS Fuel Booster, MPI Billet Lid, Jokerz race port, 2.30" upper, 107mm Soler TB, 160°F Billet DMS, Big Gulp, LPE Big Bore HPFP, XDI +30, ECM & TCM tuned by Elite Tuned, Atturo 315 AZ850DR |
05-14-2023, 10:09 AM | #26 |
Sounds easy and also less chance of a leak. Gonna look at both!
05-14-2023, 11:07 AM | #27 |
Same here, how do we get our AEM wideband to connect to the banks?
05-16-2023, 08:58 AM | #28 |
Drives: 2017 Camaro zl1 Join Date: Oct 2022
Hi guys, I'm a noob to this stuff so take it easy on me.
I got the banks idash as well because my tuner told me I should get a gauge that monitors AFR and boosts would be a plus since the one on the dash is iffy. If I'm understanding this thread correctly... the idash won't monitor afr without using some part of the aem wideband thing? I can't just buy an O2 wideband sensor and wire it to the idash? |
