06-14-2022, 07:44 PM | #29 | |
928rwhp - 93 | 1040rwhp/898rwrq - E65 SAE
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90 |
06-19-2022, 08:40 PM | #30 |
If you have HP Tuners you can also enable it.
06-19-2022, 09:08 PM | #31 | |
Drives: 2018 Camaro ZL1 Join Date: Aug 2018
It pays for itself when GM should have put one in, in the first place. |
06-20-2022, 08:45 AM | #32 |
Drives: HBM ZLE Join Date: Aug 2017
Sorry should have clarified, once you install the tank or empty and refill the system this is what I did. The hptuners way is cool, was just easier for me at the time to jump the relay
06-20-2022, 08:50 AM | #33 |
I have the Cordes ~1 gallon tank and thinking of going to one of these with a hope that MAT will be cooler due to the fact the tank won't be in the engine bay.
Right now I run 40°F +/- 10 over my IAT1 temp with stock intercoolers and Magnuson 2300, would like to see that knocked down another 10° at least with this change over. Thoughts?
06-20-2022, 08:53 AM | #34 | |
Having FUN in the SUN...
Great question... I am surprised that i can find any real data for testing on these.
06-20-2022, 12:28 PM | #35 | |
Trunk tank with ice or a chiller. I usually stay about ambient or 10 degrees above to a certain temp. When it gets past 85-95F I actually stay at ambient or slightly lower.
06-20-2022, 04:42 PM | #36 | |
06-20-2022, 06:46 PM | #37 |
I agree, my gut tells me if there was a noticeable improvement, someone would have done the back to back testing, and posted or advertised the data... If someone can point me in the right direction that would be great.
06-21-2022, 06:46 PM | #38 | |
Am i the only one surprised by the lack of testing / data on these? Anyone found some yet?
06-28-2023, 09:00 AM | #39 |
Drives: 2021 Camaro ZL1 Join Date: Mar 2023
How was the installation process of the Synergy fender tank? Did you have to remove the fender? From one of the pictures I have seen in the past and where it looks like the hoses tap in, it looks like pulling the front fascia off may have been required?
2021 Camaro ZL1 Satin Steel Metallic
Rotofab CAI, Banks Idash, AEM X series wideband, CSP 2" headers, Jet hot 2500 ceramic coating, DSX Flex Fuel Sensor, DMS Fender Tank, Velossatech Big Mouth, JMS Fuel Booster, MPI Billet Lid, Jokerz race port, 2.30" upper, 107mm Soler TB, 160°F Billet DMS, Big Gulp, LPE Big Bore HPFP, XDI +30, ECM & TCM tuned by Elite Tuned, Atturo 315 AZ850DR |
06-28-2023, 10:37 AM | #40 | |
Install was moderate... just pull the tire, and fender lining... then cut one hose to the drivers side aux HX and splice in the new hose to and from the fender tank. My issue with my yank, that i didnt realize until later, is that i think they sent me the wrong one. I had to cut some metal out of the fender area in order to fit, and had to add extra bracing for it to stay put, and not touch the inside of the fender. I still think this is a great solution for added capacity, with the benefit of the bleeder, I just wish I had the tank meant for my car :(
07-23-2023, 12:23 AM | #41 | |
Drives: 2019 Camaro SS Riverside Blue Join Date: Sep 2020
Side note: I find it interesting how the ZL1 utilizes one of the aux heat exchangers for the IC circuit, (driver's side I believe) but has no significant cooling issues within the engine coolant circuit. The SS uses both aux heat exchangers plus the main radiator for engine coolant circuit, obviously no stock SC is on an LT1 engine. All the searching I've done tells me the main radiators are exactly the same between the SS and ZL1. Thinking about tapping into my driver's side aux heat exchanger to supplement my IC coolant circuit. The Maggie 2650 and LT headers heat up my SS engine bay pretty fast when I'm in stop and go traffic a lot. Something's got to help, and I'm not too interested in the trunk tank or interchiller idea just yet. |
07-23-2023, 11:44 AM | #42 | |
What I can tell you is that during dyno and street pulls, my IAT.3's go down, not up. in 92 degree weather, my IAT.3's have never gone above 152F. Although I also customized mt fans settings to help a bit while the car is not moving. In general, i feel this was a great addition, and it is no doubt helping.
