05-12-2017, 10:20 AM | #1 |
Drives: 2016 Camaro SS Join Date: Oct 2016
Starting N20 project
So after much debate I've finally settled on the path I'm going to take with my personal car. I have nothing against FI or H/C at all but I want a setup that will work well whether I'm on the street or at the track. My car is FBO and to be honest on a street tire 1st gear is useless and 2nd is hit or miss. So the plan is...
- retain FBO setup for 99% of the time I don't need more TQ/HP - have PRAY port the MSD - get the MSD plumbed for direct port - install dual bottle setup - install separate 1 gallon fuel cell for E85 with aux pump (may run race grade E85 here) With this setup there is no reason to enhance the factory fuel system. I can run full E85 off and on the spray and not worry about fuel pressure or injector window issues. And the intake valves will get a cleaning here and there I will try and do this in a way I do everything else... clean and well thought out. If I can achieve the system I want I will probably market it as a complete package. I'm also going to test out some things to see if I can get the ECM to pull timing automatically when the system is engaged without having to swap tunes in and out. Comments/thoughts are welcome. Tim |
05-12-2017, 11:04 AM | #2 |
Drives: 2016 Black 1SS Camaro Join Date: Jul 2012
2016 Camaro 1SS M6 with MRC and NPP.
“Two things are infinite: the universe and human stupidity; and I'm not sure about the universe.” Albert Einstein |
05-12-2017, 02:58 PM | #3 |
Drives: 2018 ZL1 Join Date: Oct 2011
Should make for a fun setup. Be sure to post pictures
2018 ZL1…Many mods to come
05-12-2017, 03:29 PM | #4 |
SNSTRSS
Looking forward to it!
2016 Black Camaro 2SS A8 NP
05-12-2017, 03:47 PM | #5 |
Drives: 2016 NFG SS A8 Join Date: Jul 2014
If you and make it, it will no doubt be a high selling kit. Everything you do is top notch.
2016 NFG 1SS A8. Pray ported intake manifold, Rotofab dry cai, kooks 2" catted longtubes, E85,
05-12-2017, 04:42 PM | #6 |
Thanks. My goal is to make it as plug and play as possible with the key safety measures in place. Cheap and dirty is not the right way to do nitrous.
05-12-2017, 04:44 PM | #7 |
Drives: '17 SS/1LE/PDR Join Date: Feb 2017
looking forward to this build!
PRAY ported MSD/TB : ROTOFAB/dry : DSX flex fuel : HPA Stage 3 : ARH catted long system/oem NPP : RSR harness bar : RSD : FSO1 : MPS4S 305F/325R
05-16-2017, 09:02 AM | #8 |
Drives: 2016 2SS Join Date: Jul 2016
Still gonna be slow. LOL.
2016 2SS. H/C SBE 1.37 60ft, 6.36@109.49, 9.97@136+. Nuff Said.
05-27-2017, 11:58 AM | #9 |
SNSTRSS
Any progress with the nitrous build?
05-27-2017, 02:49 PM | #10 |
Wanting to see how this turns out..
Sub
DMS Flex Fuel-E85
HPTuners Ngauge Roto Fab CAI, LPE Ported/Polished 95mm LT5Throttle Body, PRAY Ported MSD Intake Manifold, SP Coated TSP 1 7/8" Catlless Longtubes Hooker BlackHeart Cat-Back, Mishimoto Catch Can (Which always has some nasty in it) Instagram@Weapon_6 |
05-27-2017, 07:41 PM | #11 |
Drives: 2016 Camaro 2SS M6 Join Date: Mar 2017
This is going to be Sweet! Keep us updated!
715whp/665tq
05-29-2017, 10:40 PM | #12 |
Drives: 2016 Chevy Camaro Join Date: Jun 2016
Here's a universal tank from Nitrous Express. The pump, regulator, and plumbing retail for another 500-600 bucks to complete a standalone fuel system. So roughly $1000 bucks for that, then there's the question of how you deliver the nitrous by either a window switch or a progressive system. A progressive system would be alot better but wheel hop could still be an issue. So a one piece drive shaft and upper and lower control arms should be a high concern. A full hit on a window switch , its 50/50 on just how much the stock stuff will absorb. Then there's the AFM lifters. As I'm told , they seem to not like anything above a 175hp shot of nitrous. Im yet to 100% verify this however....
06-01-2017, 10:16 PM | #13 | |
Drives: 2016 2SS coupe 2015 3LT Stingray Join Date: Aug 2012
Ported intake manifold and throttle body kooks 2" headers no cats
06-03-2017, 04:31 PM | #14 |
Drives: 2016 2SS Join Date: Nov 2011
Who Dares...Wins |
