Homepage Garage Wiki Register Social Groups Calendar Search Today's Posts Mark Forums Read
Go Back   CAMARO6 > Technical Camaro Topics > Dragstrip and Launching Discussion
Old 04-22-2017, 11:12 AM   #1
SGDM
SGDM's Avatar
Drives: 2016 2SS
Race Star Fitment
Mounted the 95 Recluse 4.5 x 17" wheels on the front today and there is plenty of clearance.
Has anyone mounted a M&H 325 x 17" tire on a Gen 6 yet? I am afraid they will be too wide. Thanks.
Who Dares...Wins
SGDM is offline   Reply With Quote
Old 05-02-2017, 04:45 AM   #2
Dubchitts
Dubchitts's Avatar
Drives: '17 Red hot 2ss, 16 Focus RS
Would I have to run an 18" wheel on front? I have 6 piston calipers and am not sure what will fit up there for skinnies
"Spitfire" 427ci
2017 Red Hot 2SS// 6 Piston Brembos//Adrenaline Red Interior, Knee Pads//M6//MRC
Afe Air Filter//BMR MM010 Motor Mounts, Safety Loop//Custom OTR Intake//Flex Fuel Kit//Gforce 3.5" Aluminum Driveshaft//GM 95mm TB//Katech Oil Pump, Piston Squirters//Kooks 1-7/8 LT//LT4 Fueling//Mighty Mouse Wild//Monster Clutch LT1-S Triple Disc//MSD 2-Step//Pray Performance Custom Spec Cam, Ported Holley Hi-Ram//Sikky 12" Shifter w OEM Knob Mod//Tick Level 1 Tr6060//Labor by Me//Tune By Pray Performance
Dubchitts is offline   Reply With Quote
Old 05-02-2017, 01:06 PM   #3
Pro Stock John
Writer
Pro Stock John's Avatar
Drives: 2010 SS / 1967 Camaro
Gonna be tight but they might work. Have a customer running 305 MTs which are pretty similar in size on RS 17x9.5s.
PROJECT HEAVY CHEVY
Camaro Now: Mods for the Masses Part I | Part II
13.15@106 1.95 | 100% Stock
12.37@112 1.85 | + Kooks Headers/Cats + 20" 555R + CAI + BW TB + UDP + Tune
12.06@113 1.70 | + CD 3200 + 18" NT05R + RCR Intake + NE OTR + GPI Tune
11.84@115 1.59 | + 3.91s + Race Star 17x7 Fronts
10.90@125 1.47 | + GPI VVT Cam + BW Ported Heads + CD 3800
Pro Stock John is offline   Reply With Quote
Old 05-02-2017, 02:07 PM   #4
bybcous
bybcous's Avatar
Drives: 2016 Hyper Blue 1SS
This guy is running 3254018m and hs not me but my buddy and he doesnt rub at all, i run 305/45/18 and i rubned out my wheel liner on drivers sode but i dont care. I have 17s out front since i got them and tires free. I have blue car.
1ss/Auto-Hyper Blue
acs carbon flash spoiler, bmr springs, gm clear tails.
Texas speed cam, 223/227 .635/.635 116 LSA, Kooks Long Tube Headers with green cats, MSD Atomic Air Force Intake, CAI Cold Air Intake, QTP cutouts. 503 hp
Best so far 11.5 at 123 with a 1.83 60ft. BMR lower and upper trailing arms and upper control arms,E85
DELIVERED 12/29/15
http://youtube.com/bybcous " no talking only racing on my youtube"
bybcous is offline   Reply With Quote
Old 05-02-2017, 03:41 PM   #5
Pro Stock John
Writer
I think 305/45/18 is too tall a tire for these cars, it's a 28.5 tall tire and stock you are more like 27.5 or 27.0...
PROJECT HEAVY CHEVY
Old 05-02-2017, 07:11 PM   #6
laynlo15
laynlo15's Avatar
Drives: 2022 Lt1 A10
Mine are 17's and 28x10-17 Hoosiers and plenty of clearance. If I go to a drag radial someday I'll run a 305 M/T
Old 05-14-2017, 08:47 AM   #7
SGDM
SGDM's Avatar
Drives: 2016 2SS
I put the skinnies on and did some high speed driving to check balance and drivability.
Who Dares...Wins
Old 05-14-2017, 08:53 AM   #8
SGDM
SGDM's Avatar
Drives: 2016 2SS
I went with the MT 305/45/17, thanks for the input.
Who Dares...Wins
Old 05-14-2017, 12:38 PM   #9
laynlo15
laynlo15's Avatar
Looking good SG.
Old 05-15-2017, 09:09 PM   #10
SGDM
SGDM's Avatar
Drives: 2016 2SS
Originally Posted by laynlo15 View Post
Looking good SG.
Thanks Bro, I am getting there.
Who Dares...Wins
Old 05-17-2017, 02:32 PM   #11
Twoblindsheep
[COTW 1/6/14]
Twoblindsheep's Avatar
Drives: 2017 1LE
question on the 1LE guys... we have bigger brakes in the front.. should i run 18s in the front instead. im running 17s in the rear with MT 305
Twoblindsheep is offline   Reply With Quote
Old 05-17-2017, 05:37 PM   #12
Dubchitts
Dubchitts's Avatar
Should be the same as my 6 piston upgrade. According to race stars their 17s will clear
"Spitfire" 427ci
Old 05-23-2017, 11:03 AM   #13
Pro Stock John
Writer
So the new 1LEs have different calipers than the regular SS? That was not the case with the 5th gen.
Before you buy 18" skinnies, make sure you have good tire options. With the 5th gen guys since they need to run 28.x tall tires, the problem is tire selection. I've only found 2 tires and they are both bias ply.
PROJECT HEAVY CHEVY
Old 05-23-2017, 01:49 PM   #14
Twoblindsheep
[COTW 1/6/14]
Drives: 2017 1LE
yeah the new 1LE has the 6 piston brembo in the front so its bigger for sure.. im not sure if the 17s would fit it.. I had 17s in the rear on my 5th gen so I should have no problem transferring those wheels to my 17 1LE
