Go Back   CAMARO6 > Technical Camaro Topics > Dragstrip and Launching Discussion
Old 05-23-2017, 02:10 PM   #15
WILWAXU
WILWAXU's Avatar
Drives: 2019 Crush ZL1 1LE
Yup.. don't think a 17 would work. This post http://www.camaro6.com/forums/showpo...5&postcount=34 has pictures of a 18x4 space saver wheel on the front of my 1LE. It's tight.
John Brown
Instagram @wilwaxu
Facebook @wilwaxu
WILWAXU is offline   Reply With Quote
Old 05-23-2017, 08:37 PM   #16
Dubchitts
Dubchitts's Avatar
Drives: '17 Red hot 2ss, 16 Focus RS
The difference would be the race stars were made for our cars and the big brakes vs the gto spares.
I would call race stars. The 92 bracket racer is what I inquired about, they assured me the 17X4.5 would clear the 6pistons. The recluse could be different. I hope not because I think those look awesome on the ops car
I know it won't be the same backspace/offset but I can mock up my rear wheels on the front to see if the inner diameter of the wheel would clear. If it does then it's a matter of will the spokes clear
"Spitfire" 427ci
2017 Red Hot 2SS// 6 Piston Brembos//Adrenaline Red Interior, Knee Pads//M6//MRC
Afe Air Filter//BMR MM010 Motor Mounts, Safety Loop//Custom OTR Intake//Flex Fuel Kit//Gforce 3.5" Aluminum Driveshaft//GM 95mm TB//Katech Oil Pump, Piston Squirters//Kooks 1-7/8 LT//LT4 Fueling//Mighty Mouse Wild//Monster Clutch LT1-S Triple Disc//MSD 2-Step//Pray Performance Custom Spec Cam, Ported Holley Hi-Ram//Sikky 12" Shifter w OEM Knob Mod//Tick Level 1 Tr6060//Labor by Me//Tune By Pray Performance
Dubchitts is offline   Reply With Quote
Old 05-23-2017, 10:10 PM   #17
WILWAXU
WILWAXU's Avatar
Wink
My pictures were for information only.. that's my spare. Not a race setup
John Brown
Instagram @wilwaxu
Facebook @wilwaxu
Old 05-28-2017, 08:51 AM   #18
SGDM
SGDM's Avatar
Drives: 2016 2SS
Rear Race Star Wheels
The rear wheels, 10.5 x 17" arrived this week and here are pics of fitment. Everything clears and looks like plenty of room, tires will be mounted and I will get them on car ASAP.
Who Dares...Wins
SGDM is offline   Reply With Quote
Old 05-28-2017, 09:01 AM   #19
SGDM
SGDM's Avatar
Drives: 2016 2SS
Wheel/Tire Weight
I reduced the weight by 102 lbs compared to the stock wheels and tires, hopefully good for a tenth! It has come down to weight reduction and contact patch at this point...
Who Dares...Wins
Old 05-29-2017, 03:36 PM   #20
Dubchitts
Dubchitts's Avatar
I test fit my rear race stars on the front just to see if their 17" would clear the 6piston calipers. It appears they would work, but it's very close!!
These are my 17x9.5 with the lugnuts fully seated,but not torqued. I spun the wheels around as fast as i could and didnt hear any rubbing and i didnt see any scrapes on the inside of the wheel. As long as the spokes clear i would think the 17x4.5 will fit.
"Spitfire" 427ci
Old 05-29-2017, 08:42 PM   #21
Twoblindsheep
[COTW 1/6/14]
Twoblindsheep's Avatar
Drives: 2017 1LE
youre awesome for trying it out.. my racestars was that close in the rear on my 5th gen.. i actually had to grind my calipers off a bit..
Twoblindsheep is offline   Reply With Quote
Old 05-29-2017, 08:51 PM   #22
SGDM
SGDM's Avatar
Drives: 2016 2SS
I wish you were closer, you could run over and we would throw em on. I talked in depth and detail with em prior to pulling the trigger. You will be good with the 4.5 x 17s.
Who Dares...Wins
Old 05-29-2017, 09:51 PM   #23
Dubchitts
Dubchitts's Avatar
Yeah that would be cool! Maybe If I bring a jack and stands, another member that runs 131 motorsports park might let me do a quick test fit I only know of one other member that runs there with that setup
But I really doubt it would be an issue I wouldn't think my calipers are wider than the standard brakes. Getting them balanced might be questionable tho!
"Spitfire" 427ci
Old 05-31-2017, 09:24 AM   #24
Pro Stock John
Writer
Pro Stock John's Avatar
Drives: 2010 SS / 1967 Camaro
What I do if I"m concerned if a wheel will rub, is put tape on the caliper first. Thick tape will protect it and will tear first.
PROJECT HEAVY CHEVY
Camaro Now: Mods for the Masses Part I | Part II
13.15@106 1.95 | 100% Stock
12.37@112 1.85 | + Kooks Headers/Cats + 20" 555R + CAI + BW TB + UDP + Tune
12.06@113 1.70 | + CD 3200 + 18" NT05R + RCR Intake + NE OTR + GPI Tune
11.84@115 1.59 | + 3.91s + Race Star 17x7 Fronts
10.90@125 1.47 | + GPI VVT Cam + BW Ported Heads + CD 3800
Pro Stock John is offline   Reply With Quote
Old 05-31-2017, 10:15 PM   #25
SGDM
SGDM's Avatar
Drives: 2016 2SS
Yes sir, good idea. Nothing a grinder and Krylon can't fix.
Who Dares...Wins
Old 06-01-2017, 04:57 AM   #26
WILWAXU
WILWAXU's Avatar
Wink
Never done that before...
John Brown
Instagram @wilwaxu
Facebook @wilwaxu
Old 06-01-2017, 02:29 PM   #27
Dubchitts
Dubchitts's Avatar
When I get skinnies I want one of these as well, so I don't ding the paint in the calipers when installing the wheels.
https://zl1addons.com/collections/ac...nt=27721726721
"Spitfire" 427ci
Old 06-01-2017, 09:49 PM   #28
SGDM
SGDM's Avatar
Drives: 2016 2SS
Now that...is cool.
Who Dares...Wins
