04-25-2023, 11:37 AM | #1 |
Chassis Brace, Rear Of Rear Cradle CB009R For 2016-2023 Camaro
Reduce wheel hop and cradle movement and deflection on your 2016-newer Chevrolet Camaro with a rear Cradle Brace from BMR Suspension. Built from heavy-duty, yet lightweight 1 1/4-inch Chrome-moly tubing, BMR’s CB009 rear Cradle Brace is designed to greatly reduce cradle deflection, which is one of the biggest causes of wheel hop. BMR’s CB009 attaches to the rear section of the cradle and frame to strengthen the entire assembly. The brace captures the bottom side of the cradle mounts, making each rear mount double sheer. This mounting style adds strength and reduces deflection. The brace also mounts to the frame, eliminating any cradle deflection caused by the factory single sheer mounts. BMR Suspension designed the CB009 rear Cradle Brace for any application. This lightweight 100% bolt-on kit uses existing boltholes and supplied hardware, allowing for easy installation with simple hand tools. Once installed, the Cradle Brace greatly reduces cradle deflection. BMR Suspension’s CB009 rear Cradle Brace is a lightweight and affordable way to effectively lessen wheel hop and cradle movement on your Sixth Gen Camaro. NOTE: This part is not compatible with convertibles, ZL1, or other models equipped with Electronic differential BMR Suspension’s CB009 rear Cradle Brace is available in black hammertone and red powder coat for long-lasting good looks. Installation time is about 1 hour. Proudly made in the U.S.A.! - 100% bolt-on design - No fabrication is needed - Installs with simple hand tools - Lightweight design - 1 1/4-inch Chrome-moly tubing - Greatly reduces stock cradle deflection - Used factory boltholes and supplied hardware - Durable powder-coat finish - Available in black hammertone and red Powdercoat - Proudly designed in the U.S.A. - Proudly built in the U.S.A. Available in Colors: Black Hammertone Powercoat Red Powercoat Fitment: 2016, 2017, 2018, 2019, 2020, 2021, 2022, 2023 Camaro |
