05-22-2022, 05:05 PM | #1 |
Drives: 2014 2LT RS Join Date: Nov 2016
What is this?
I’m no mechanic, is this spring attachment aftermarket? If so, what purpose does it serve? Thanks! https://www.camaro5.com/forums/attac...1&d=1653256947
05-22-2022, 07:15 PM | #2 |
It don’t come easy.
Invalid attachment
05-22-2022, 07:38 PM | #3 |
Sorry here’s the pic. |
05-22-2022, 07:54 PM | #4 |
376 cubic inches of fun
It "adjusts" spring rate by shoring out one turn of the coil to stiffen the spring. It has a threaded rod with the the ability to adjust further, but the "adjustment" has little effect compared to just taking out one coil.
It is a piece of s#i#. Take it off and throw it away before it causes the spring to break. |
05-22-2022, 07:59 PM | #5 |
Is it just as simple as loosening the inner nuts to remove it?
05-22-2022, 08:13 PM | #6 |
Looks like it. Make sure that corner is off the ground to release the spring tension a bit when you do it
2010 2SS/RS
05-23-2022, 06:37 AM | #7 |
05-24-2022, 11:29 AM | #8 |
I take it someone added this. For what purpose you think?
05-24-2022, 12:17 PM | #9 |
Instagram: Mr2Hard2See
Drives: 2011 2SS/ RS Join Date: Apr 2018
These are for lifting the car up by spreading the coils out. It’s a thing you see on the donk cars to fit larger rims. If you flip the top bracket 180* and tighten it can compress the spring to give a lower look like a drop spring.
If you remove that your ride quality should increase a bit and not be as stiff.
YOUTUBE CHANNEL: Mr2Hard2See
LSA blower BTR stg 2 cam 227/242 BTR dual springs pushrods lifters retainers etc Che bronze trunnion Ls3 timing/valley cover Dod/vvt delete Dsx e85 Dsx aux fuel pump Id1050x injectors ZL1 fuel pump, Griptech 2.55 pulley, Solo performance Mach ll 2.5 catback exhaust 1 7/8th Lt headers |
05-24-2022, 12:18 PM | #10 |
Instagram: Sangstah
sketchy stuff, remove immediately!
2019 SS 1LE - "CaSSandra" 2014 SS - "AleSSandra - Sold" 94 Z28 - Sold
Follow the build https://www.camaro6.com/forums/showthread.php?t=612717 |
05-25-2022, 06:16 PM | #11 |
Don't think I have EVER seen anything like that on a Camaro before!! lol. Take it off and toss it!!
05-26-2022, 07:31 AM | #12 |
They're in the garbage bin. Thanks to everyone!
05-26-2022, 08:02 AM | #13 |
Nice. And you will notice the car riding much smoother. Cheers!!
