08-04-2020, 09:53 AM | #1 |
Drives: 2015 Chevrolet Camaro SS Join Date: Feb 2018
Melling oil pump - L99 with DOD and VVT deleted
I completed a cam upgrade on my 2015 Camaro SS 6.2L L99 and removed the DOD and VVT components. While doing so I replaced my oil pump with a Melling M295 pump and I get 28 lbs or pressure hot at idle and approx 50 lbs at 5000 RPM’s. We are about to get back into the engine again, should I switch this pump back to the OEM L99 oil pump? Which pump do I need?
Thank you in advance for your help. |
08-04-2020, 01:51 PM | #2 |
Drives: 2010 Camaro 2SS Join Date: Mar 2018
I believe those numbers are right where they should be.
08-04-2020, 03:25 PM | #3 |
With VVT deleted you are good with those numbers. If you had kept VVT I would have considered the Melling 10296 HV pump. That is what I run and my hot idle is at 42-43 lbs and over 5k rpms I am over 60 lbs. I didn't really need these higher pressures with an LS3 but since the engine came with the pump and it was new, I ran it.
08-05-2020, 06:47 PM | #4 | |
08-06-2020, 05:02 PM | #5 | |
Drives: 2015 Camaro SS convertible L99 Join Date: Nov 2016
