01-25-2019, 12:26 PM | #1 |
Drives: 2016 ss camaro Join Date: Jan 2018
MSD+ROTOFAB+GRANATELLI WIRES
Hey, everyone just wanted to share my latest bolt on set up and Dyno numbers. I swapped out my ported lt1 manifold with the 95mm t/b and AFE cold air intake. We went with and MSD/95mm and Roto-fab. Car picked up and additional 14hp/5tq. Not very impressed in all honesty. However, while on the dyno I swapped out my ignition wires with a set of Granatelli's and car picked up an additional 4/4, which I though was pretty impressive considering I already had holly wires on there. That's insane!! total gains 18hp/9tq.
See dyno video here: https://youtu.be/ydK14-oJBYU First picture is base line of the msd/rotofab against ported lt1/95 and afe Second is zoomed in to show the power loss down low. Just a bit, nothing to crazy Third picture shows base line in green, msd/rotofab in red and wires in blue. (final #'s all dialed in) Tuner was Kike fab and tune in Baldwin park.
01-25-2019, 12:40 PM | #2 |
Nice can you post of a copy of the chart?
Did u ever take off the Holly’s and reinstall them? I notice a lot of times the wires can’t handle getting yanked on
‘16 1SS M6 LT2 intake + boltons on DR 11.0@126+ (Sold) Last edited by 6spdhyperblue; 01-25-2019 at 01:17 PM. |
01-25-2019, 01:38 PM | #3 |
Yeah ill post the chart here shortly and No, I kept the granatelli's. Don't think ill get back in there for a while. But definitely a good idea to test the ohm resistance in a few thousand miles.
01-25-2019, 01:48 PM | #4 | |
Drives: SS 6 speed of course Join Date: Jan 2016
Looking forward to the dyno and seeing the MSD performance down low.
01-25-2019, 03:09 PM | #5 |
Drives: 2017 Camaro 1SS M6 (SOLD) Join Date: Oct 2016
Good to know you saw a gain with just the Granatelli plug wires, I have a set to install with a bunch of other mods. I damaged a boot when I originally installed the Whipple. And since I am doing headers I figured its the perfect time for new plugs and wires since I am right there.
2017 1SS M6 Hyper Blue Metallic NPP, MMR 228 Z/28 replica wheels, Front: 20 x 9, Rear 20 x 11
Stock: 416hp/427tq, 12.21 @ 116.80 Modified 02/2019: Whipple SC w/ 3.500 pulley, LT4 fueling, NW 103 TB, Roto-Fab Big Gulp, Kooks 2" jet coated, full Borla ATAK exhaust, DSS axles, Gforce driveshaft. Tuned by EFX Tuning 688hp/632tq Best 1/4 to date: 10.705 @ 131.92 |
01-25-2019, 03:22 PM | #6 |
Drives: 2018 2ss 1le Join Date: Jan 2018
btw
tuned or untuned and maybe its in there and I cant read …. but ported msd or not
2018 2ss 1le roto fab dry, Stainless works 1 7/8 lt to 3'" x pipe with highflow cats to stock npp, soler 95mm t/b, edelbrock 2300, LT4 fueling , jms bap and dsx flex fuel, 618/620 on e45 rwhp
Jannetty Motorsports tuned |
01-25-2019, 03:44 PM | #7 |
I want to get the new varam intake. Once out I will do a shoot out against the stock air box. should be interesting.
01-25-2019, 03:48 PM | #8 | |
https://youtu.be/XCmnkkaQqOg
01-25-2019, 03:49 PM | #9 |
I apologize for the poor pictures but here are a few.
01-25-2019, 06:10 PM | #10 |
Drives: 2010 camaro Join Date: Dec 2017
are you happy with the msd for a daily driver? are you missing that low end torque and power
01-25-2019, 06:50 PM | #11 | |
Drives: 2018 SS 1LE Join Date: May 2018
🌽 Sauced, 2018 SS 1LE - 123mph @ 5,000 DA
ARH 2”x3” FULL System, Pray Ported MSD Intake Manifold, Pray Ported GM 95mm TB, RotoFab CAI, DsX e85 Kit, MightyMouse Catch Can, NicD Tune https://instagram.com/corn_sauced?ut...d=o0ako89uurwl |
01-25-2019, 08:34 PM | #12 |
exactly which wires did you get,
I have headers and like the grey and black color
01-26-2019, 12:24 AM | #13 |
Can't really tell a difference down low but feels stronger on the top end. It drives good, I don't think you will be disappointed.
01-26-2019, 12:29 AM | #14 | |
check them out: https://www.granatellimotorsports.co...parent=24&pg=1
