Old 06-14-2022, 01:22 PM   #1
Slvr-camaro15
Slvr-camaro15's Avatar
Drives: 2017 zl1 ,2010 SS /RS L99
Weld wheels question
This question has probably been answered prior , but I wasn’t able to find the answer or didn’t know where to look so just wanted to know. I have a set of welds 17x10 with Mickey Thomson et street ss 305 x45x17 on my 2010 camaro rears . Will I be able to put them on my 2017 zl1 or do I need to modify anything? Any input will be greatly appreciated.
2017 zl1 - rotofab CAI , PDR , Nav .
2010 camaro SS - Procharger D1 sc (Stage 2 with upgraded intercooler)+ whole lot of other goodies ( too many to list )
Slvr-camaro15 is offline   Reply With Quote
Old 06-14-2022, 04:37 PM   #2
Trochoidal
Drives: 2017 Camaro 2SS A8
What is the offset of your 17x10’s? +43?
Originally Posted by arpad_m - “Aww, yet another oil thread with almost the same question in the OP“
Trochoidal is offline   Reply With Quote
Old 06-14-2022, 05:27 PM   #3
Slvr-camaro15
Oh man !! I’m not even sure . I purchased them from someone, only thing I know is I had to tie the e brake cable on the 5th gen camaro ss so it would rub on the inside of the wheel. I’m sorry , I wish I had more info to give you.
Old 06-14-2022, 05:33 PM   #4
Trochoidal
No worries. Well, I’d just pull one wheel and see what you get for fit. Do you have both cars or are you getting ready to buy the ZL1 and want to keep them from your 5th Gen?
On the SS’s it’s a good idea to relocate the wiring harness on drivers side just to be safe. Maybe a 30 minute job. It might not need it on the ZL1.
For reference:
https://www.camaro6.com/forums/showthread.php?t=485975
Old 06-14-2022, 06:09 PM   #5
Phil zl1
Drives: 2022 zl1
Go to tire rack on the net and see the offset center hub etc.For both models .You ll get your answer.
Phil zl1 is offline   Reply With Quote
Old 06-14-2022, 06:22 PM   #6
Slvr-camaro15
For reference:
I appreciate the suggestion . Maybe I’ll pull them off and fit them on the zl1 and take it for a spin to see if there are any issues. I’m wondering if there is any information on where to zip tie the e-brake cable on the zl1 to prevent interference.
I have both, don’t drive the ss much , enjoying the zl1 for now!! The rear tires on the zl1 are a bit worn out so wanted to put the welds on there instead of spending another 700-800 on new set of tires.
Old 06-14-2022, 06:23 PM   #7
Slvr-camaro15
Gotcha !! Thank you
Old 06-15-2022, 07:41 AM   #8
Choda
Drives: Turbo 6.2
id just test fit it in the garage. should take 5 min
2016 Turbo Camaro SS - 800hp/900tq 9.7@146
2018 LTZ Z71 Redline Silverado - 381hp/420tq 13.8@100
Choda is offline   Reply With Quote
Old 06-28-2022, 06:49 AM   #9
Slvr-camaro15
Update
It’s a success . I was pleasantly shocked hearing about the rubbing etc . I didn’t have to touch or modify anything!! It’s a blessing !!! Bolted right up and no scraping, no weird noises or anything !!! Loving it !!! THANK YOU EVERYONE FOR all your advice!!🙏🏻🙏🏻🙏🏻🙏🏻
Old 06-28-2022, 06:10 PM   #10
Trochoidal
Ahhh, that’s good news. So you ended up with what you wanted and it does look good.
Old 06-28-2022, 07:11 PM   #11
Slvr-camaro15
Thank you so much 🙏🏻🙏🏻🙏🏻
For straightening up the image as well 🙏🏻🙏🏻🙏🏻🙏🏻
Old 06-28-2022, 07:14 PM   #12
Slvr-camaro15
Added oem mudguards
What you guys think ??
Old 06-28-2022, 08:54 PM   #13
Trochoidal
You’re welcome.
I’m a fan of the color, wheel setup and the OEM mud guards!
Old 06-28-2022, 09:44 PM   #14
Slvr-camaro15
You’re welcome.
Yessss !!! Thank you !!! Your setup looks killer 🔥🔥🔥🔥
