12-23-2020, 06:23 AM | #15 | ||
https://www.lethalgarage.com/product...d8ecfe34&_ss=r Quote:
2010 Camaro 2SS Cam/Headers/CAI/3.91 gears 476 rwhp/440 rwtq (sold) |
12-23-2020, 06:42 AM | #16 | ||
I have no ideal if I have a long term solution. I suspect that as my battery ages and becomes less able to push its rated voltage and amps - the heat soak load may be enough by itself to bring back the problem even though I have significantly reduced the load resistance issue with a better engine to body ground. As I said in my first post I decided to just try something easy before I got into buying an expensive new battery and/or replacing the starter. I was surprised I got any positive results let alone such a dramatic improvement with a new ground cable. My car must have poor/loose factory grounding I guess.
2010 Camaro 2SS Cam/Headers/CAI/3.91 gears 476 rwhp/440 rwtq (sold) Last edited by SSDan; 12-23-2020 at 07:55 AM. |
12-23-2020, 09:21 AM | #17 |
Drives: 16 Camaro SS, 15 Colorado Join Date: May 2009
This is good stuff. Thank You for contributing to this community!
2010 Camaro 1LT V6 (Sold. I will miss her!) |
12-23-2020, 09:42 AM | #18 |
Drives: 2017 Camaro 2SS Join Date: Jul 2016
Good job!
2017 2SS A8 TSP LT's, ported msd/95 mm, e85
12-23-2020, 10:30 AM | #19 |
Drives: 2016 Camaro 2SS Join Date: Apr 2018
What gauge is the one from Lethal's website?
12-23-2020, 10:53 AM | #20 |
I'm unsure. Its plenty thick. Definitely bigger than the grounds that are on the car and the one from AutoZone - at least to my eye.
2010 Camaro 2SS Cam/Headers/CAI/3.91 gears 476 rwhp/440 rwtq (sold) Last edited by SSDan; 12-23-2020 at 11:14 AM. |
12-23-2020, 11:13 AM | #21 |
Drives: '16 2SS M6 Join Date: Aug 2019
The one you got looks to be 1/0 welding cable (fine strands, very flexible). I have made industrial battery cables with that stuff for years and also made the cables for my Jeep out of it. Makes a huge difference over the crappy 4ga cable from the parts stores.
David
'16 2SS M6 black on black, SW long tube full exhaust, NPP, Roto-fab CAI, ported stock TB '16 2SS M6 black w/Metallic black stripes, Kalahari, 6 piston front (totaled 1/22/20) '14 Fusion Titanium 2.0T '83 Jeep Wagoneer |
12-23-2020, 11:32 AM | #22 |
Drives: 2018 ZLE Join Date: Jul 2014
I had this issue and fixed is the same way on my 10SS...I'm hoping LT4s are immune to it as I haven't experienced it yet
12-23-2020, 12:06 PM | #23 |
Drives: 2018 Camaro 1SS 1LE Join Date: Feb 2020
I haven't had any hot start issues with my 2018 1LE but I am still going to be adding the ground wire. The one thing I have always tried hard to do is have a reliable car. The idea of missing a commitment because "my nice fancy hot rod car wouldn't start" just rubs me the wrong way. I have some unused 0 gauge wire from my car audio days that I am going to use. Now I just have to get off my lazy butt and lift that thing so I can get under there and do the install, along with the new Soler TB and Gen5DIY seat cooling wiring harness. Would probably be a little more motivated if it wasn't <25° outside. I have been in Colorado for 3 months and my SoCal blood hasn't thickened up enough yet.
EDIT: I just watched the video about where you put your ground wire and I will probably be installing mine today since I don't have to get under the car to do it. Thanks!! Last edited by Rhobz; 12-23-2020 at 12:51 PM. |
12-23-2020, 12:15 PM | #24 |
Drives: 2021 2SS Join Date: Jul 2020
What bolt size to attach the opposite end to the engine block? I assume you have to buy that, as mine has no bolt in that position from the factory.
12-23-2020, 12:16 PM | #25 |
This article describes a multi-pronged approach to the "heat soak" problem. Just note, the "physics factoid" in paragraph 3 is more of a "wrongoid" when it comes to the math. The resistance in that example would be close to 1.3 ohms, not 1.5.
http://www.roddingroundtable.com/tec...s/heatsoak.php |
12-23-2020, 01:13 PM | #26 | |
Lethal Camaro
Drives: 16 2SS, 71 Std, Suburban RTS Join Date: Jun 2013
Hey guys! Thanks for the tags and links. I can't take credit here as the cable was made by Ofer at Gen5DIY, but I do offer it on my site as a reseller.
The issue came about with Ofer's Z/28 and from numerous 5th and 6th Gen 1LE's getting hot and slow starting or not starting at all at the track. We did some testing and you can see due to the grounding cables the car was trying to draw either too much voltage or not enough at start causing the slow issue or not starting at all issue. The cable is bigger than a zero gauge to make sure its a solid ground vs GM's baby wiring. We typically go from the trans to the body, but you can hook it up like the OP or even post from the battery to the body. The entire point is to introduce a much better ground. That being stated, this isn't a be all end all work around, in some cases we found adding 2 cables exponentially improved the fix. While I don't think anyone should have to pay money to fix an issue GM didn't solve, it can save you a lot of money in needing a new starter or costs in having a dealer try to solve the problems. But you're not alone in your issues and this is a quick easy solve even GM should roll out. They currently have a lawsuit submitted on this, but no updates.
12-23-2020, 01:19 PM | #27 | ||
I don't mind paying a little extra over some el cheapo autozone stuff and helping Gen5DIY make a few bucks for a great idea and a decent job on their custom parts (I have more than a few now). Walmart mentality does not apply here
12-23-2020, 02:19 PM | #28 |
Drives: 2016 Camaro SS M6 Join Date: Oct 2016
Thank you. I just ordered a cable from Lethal. A little Christmas present that I actually want... for myself. lol.
