05-25-2021, 08:07 PM | #1 |
Drives: 2012 Camaro SS Join Date: Feb 2016
Run wires through firewall
Hey folks,
I have a 2012 manual SS and need suggestions on the best place to run wires and a vacuum line through the fire wall. Any suggestions would be greatly appreciated. Thanks!
2012 Camaro 2SS
1971 Monte Carlo SS 454 2006 Cobalt SS |
05-25-2021, 09:09 PM | #2 |
Valkyrie14
Drives: Chevrolet Camaro SS Join Date: Mar 2020
The steering wheel grommet.
2014 SS LS3/LSA Supercharger, 10% Super Damper, 2.55 upper, AGP Dual Pump, ID 1050 injectors, Pegasus solid rear cradle bushings, LT Headers, Roto-Fab CAI, Elite E2 catch can, E85 corn fed, 160 Thermostat, Monster Twin Disk, MGW Short Throw shifter, Tick Clutch Master Cylinder, HP Tuners, JL Audio system.
05-25-2021, 09:10 PM | #3 |
2&THEHIT
Drives: 5th Gen Camaro; 5th Gen Ram 3500 Join Date: Mar 2018
There’s a factory hole just below the booster. I have 2 step, line lock, boost regulator, tach signal, and headlight signal all through there.
05-25-2021, 09:32 PM | #4 |
Drives: Never just fly under the radar Join Date: Jul 2015
A few pictures into the below thread they ran the wires by the cabin filter. I ran mine on the drivers side below the booster(if I remember right) there is a grommet just plugging a hole. Really had to search for it but its there.
https://www.camaro5.com/forums/showthread.php?t=547943
Old Skool |
05-25-2021, 09:39 PM | #5 | ||
Old Skool |
05-25-2021, 10:03 PM | #6 |
I am not "Fast & Furious"
Drives: 2010 Camaro LSX454 1LE Join Date: Nov 2008
The hole in the drivers side firewall is right above where the red main battery cable goes through. To the right of the booster. It is hard to reach, but it’s there. The picture is tilted to the right.
The day I take a bend too fast
Judgement that could be my last I'll be wiped right off the slate Don't wait up 'cause I'll be late, I'll be late |
05-25-2021, 11:30 PM | #7 |
Yup. I ran my front camera through this. It has plenty of space to run multiple wires.
05-25-2021, 11:57 PM | #8 |
Drives: Camaro Convertible 2014 1LT Join Date: May 2019
Yup, great place to run more than one wire and as mentioned, there's a grommet so no worries about shorting the wires.
05-26-2021, 06:21 AM | #9 |
Thanks everyone, found the grommet above the battery cable. Will use that to run my line lock, shift light and boost a pump vacuum line.
2012 Camaro 2SS
