08-28-2016, 10:34 AM | #1 |
Sway bar issue with caliper (FIXED)
Ok so I just got done doing the FE4 switch over on my 2010. I am using the 1LE struts with Pedders linear springs. I have a ZL1 PFadt rear sway bar. I want to put my rear Brembos on but they don't have any room to mount. Any ideas? Has anyone else had this issue?
I swapped it to the 1LE sway bar. Problem fixed. Last edited by Jayzmaro10; 08-28-2016 at 01:51 PM. |
08-28-2016, 12:09 PM | #2 |
Never mind figured it out can close this thread.
08-28-2016, 12:31 PM | #3 |
Drives: 2015 Convertible Camaro 1LT Join Date: Jul 2016
how did you paint those calipers? i like the color and the finish.
08-28-2016, 01:30 PM | #4 |
Drives: 2011 Camaro 1SS Join Date: Feb 2016
Perhaps add *FIXED* to the title and explain what you did to fix it. That way when someone searches for this problem down the road you will have helped out a fellow Camaro5 member.
2011 SGM Camaro 1SS/RS A6 - Vengeance Racing built/tuned. 590RWHP/560RWTQ, ADM LSA Conversion, 2.5 Grip-Tec, ZL1 fuel pump, ADM FPCM, FIC1000, VRPD2 Cam and LS3 Conversion with all the internal goodies, American Racing 1 7/8 Headers, no cats, SW Retro Cat Back, ADM Intake, AFCO HX, Varimax Pump, Rotofab Reservoir, B&M Transmission Cooler, VMAX TB, Elite Engineering CC, BMR LCAs, Trailing Arms, Toe Rods, DSS 1000hp axles, ZL1 Bumper and Sideskirts, Night Owl Halos, Matte Black 20" Rohana RC-22 with 20x10-275s/20x11-315s, R1 Concept Premier Drilled/Slotted Rotors, Hawk Ceramic Pads.
08-28-2016, 01:52 PM | #5 |
They are shot with High Temp Cerakote. It's a custom mixed batch I made specifically to match my car. I absolutely love using it. It has natural repellant properties so keeping them clean is super easy.
08-28-2016, 01:53 PM | #6 | |
waiting at the tree
Unbolt the sway bar and bolt up the caliper then reattach the sway bar. That looks to be how its done.
2010 2SS/RS A6 ZL1 Rims
08-28-2016, 01:54 PM | #7 |
waiting at the tree
They do look nice
08-28-2016, 02:39 PM | #8 |
How much heat can the cerakote handle!!!
Orange Krush II
08-28-2016, 04:50 PM | #9 |
08-28-2016, 06:17 PM | #10 |
