Roto-Fab
Old 05-25-2021, 08:07 PM   #1
premad
premad's Avatar
Drives: 2012 Camaro SS
Run wires through firewall
Hey folks,
I have a 2012 manual SS and need suggestions on the best place to run wires and a vacuum line through the fire wall. Any suggestions would be greatly appreciated.
Thanks!
2012 Camaro 2SS
1971 Monte Carlo SS 454
2006 Cobalt SS
premad is offline   Reply With Quote
Old 05-25-2021, 09:09 PM   #2
Valkyrie14
Valkyrie14
Valkyrie14's Avatar
Drives: Chevrolet Camaro SS
The steering wheel grommet.
2014 SS LS3/LSA Supercharger, 10% Super Damper, 2.55 upper, AGP Dual Pump, ID 1050 injectors, Pegasus solid rear cradle bushings, LT Headers, Roto-Fab CAI, Elite E2 catch can, E85 corn fed, 160 Thermostat, Monster Twin Disk, MGW Short Throw shifter, Tick Clutch Master Cylinder, HP Tuners, JL Audio system.
Valkyrie14 is offline   Reply With Quote
Old 05-25-2021, 09:10 PM   #3
joshnmn
2&THEHIT
joshnmn's Avatar
There’s a factory hole just below the booster. I have 2 step, line lock, boost regulator, tach signal, and headlight signal all through there.
Old 05-25-2021, 09:32 PM   #4
Tajefe Couple
Tajefe Couple's Avatar
Drives: Never just fly under the radar
A few pictures into the below thread they ran the wires by the cabin filter. I ran mine on the drivers side below the booster(if I remember right) there is a grommet just plugging a hole. Really had to search for it but its there.
https://www.camaro5.com/forums/showthread.php?t=547943
Old Skool
Tajefe Couple is offline   Reply With Quote
Old 05-25-2021, 09:39 PM   #5
Tajefe Couple
Didn't see the reply from Josh but same place I ran my wires. Somewhere on the forum their is pics someone posted of the grommet location.
Old Skool
Old 05-25-2021, 10:03 PM   #6
AG454
I am not "Fast & Furious"
AG454's Avatar
Drives: 2010 Camaro LSX454 1LE
The hole in the drivers side firewall is right above where the red main battery cable goes through. To the right of the booster. It is hard to reach, but it’s there. The picture is tilted to the right.
The day I take a bend too fast
Judgement that could be my last
I'll be wiped right off the slate
Don't wait up 'cause I'll be late, I'll be late
AG454 is offline   Reply With Quote
Old 05-25-2021, 11:30 PM   #7
InFiD3ViL
InFiD3ViL's Avatar
Drives: 2010 CGM 2SS/RS LS3 Swapped A6
Yup. I ran my front camera through this. It has plenty of space to run multiple wires.
InFiD3ViL is online now   Reply With Quote
Old 05-25-2021, 11:57 PM   #8
joekono
joekono's Avatar
Drives: Camaro Convertible 2014 1LT
Yup, great place to run more than one wire and as mentioned, there's a grommet so no worries about shorting the wires.
joekono is offline   Reply With Quote
Old 05-26-2021, 06:21 AM   #9
premad
premad's Avatar
Thanks everyone, found the grommet above the battery cable. Will use that to run my line lock, shift light and boost a pump vacuum line.
2012 Camaro 2SS
2006 Cobalt SS
