04-07-2021, 05:29 PM | #1 |
Drives: 2017 ZL1 A10 & 2021 BMW M340i x Dr Join Date: Mar 2009
Finally put my new wheels on
So, these are Weld Racing 17x 10 rears and 18x8 fronts. I went with Nitto G2 up front with R2 rears. I installed oem tpms sensors using the strap kit on all 4. I will not be leaving this setup on the car til I have worn out the tires on my oe wheels. At that point I will leave the new stuff on.
Ignore the fender tire gap as I just lowered the car back down and took pics so the springs need to settle again.
Sold 2012 2LT RS 12.3@112 old setup
Sold 1967 Camaro Pro Street. Ran 10's mild BB on NOS. 2017 HyperBlue ZL1 A10 ** Born 3/17/17**Delivered 4/08/17 2020 Build: Mag2650, BTR Stage2, NW103, BG, 14% lower, 90mm upper, ARH 2" Long system w/no cats, SW Legend mufflers. **807hp/762tq on 93 gas** and **848hp/792tq on e47** Sold 2018 (Go Mango) Dodge Charger Daytona 392 Daily Driver Daily Driver 2021 BMW M340i Xdrive |
04-07-2021, 05:50 PM | #2 |
Drives: '17 ZL1 M6 Join Date: Apr 2021
Mean looking set up !
04-07-2021, 05:50 PM | #3 |
Drives: 2017 Chevrolet Camaro ZL1 M6 Join Date: Jul 2020
Badass Car! I am ordering the same rims for mine. I was waffling a little - until I saw yours. Thank you. What strap kit did you use for your sensors? Also, what size tires did you get? I'm thinking 245x50R18 Nitto Invo in the front and 305x45R17 Nitto R2's in the back. The only G2 I could find were 235x50R18 and they are 1/2" shorter than the rears. I can get the Invo with the same height as the rear.
04-07-2021, 05:58 PM | #4 |
Looks great for a drag setup. My favorite drag wheels at the moment.
04-07-2021, 05:59 PM | #5 |
The fronts are p245/45 and rears 305/45
04-07-2021, 06:00 PM | #6 |
Thanks. What strap kit did you use?
04-07-2021, 06:07 PM | #7 |
I got it from Amazon
04-07-2021, 06:07 PM | #8 |
The guy at Weld told me to keep the tires within 1/2" of each other in height. That more than that might upset the computer. Everything is working well, so far?
04-07-2021, 06:10 PM | #9 |
I tried to keep the tires close to stock diameter. I believe my fronts are almost exact. I also bought the oe tpms sensors from Amazon as they had the lowest price. I believe rears are 27.2 stock and these are 27.8
04-07-2021, 06:36 PM | #10 |
2019 ZL1 1LE MY GOON
Drives: 1980 Z28 Big Red. Join Date: Dec 2018
04-07-2021, 06:50 PM | #11 |
Is this the TPM sensor you got? ACDelco 13598787 GM Original Equipment Tire Pressure Monitoring System (TPMS) Sensor Kit with Sensor and Stem
04-07-2021, 07:12 PM | #12 |
Yes
04-07-2021, 07:18 PM | #13 |
Cool. Thanks.
04-07-2021, 07:22 PM | #14 |
Just finished doing the tpms relearn.
