05-06-2010, 09:51 PM | #1 |
Drives: 2SS/RS ABM Camaro Join Date: Nov 2009
Floating the Gears?
So, I experimented with "floating" the gears in my M6 SS today. Seems rather easy between 1800 and 2000 to slip it right into gear. However, I got to thinking...does this do any damage to the synchros in the tranny?
05-06-2010, 10:16 PM | #2 |
2010 Camaro 2 SS/RS M6
Drives: 2010 Camaro SS/RS Join Date: May 2009
do u mean shifting without using the clutch?
Forged LS3, FED M311 heads, CAI Inc, ARH 1 7/8, Corsa Xtreme, Taylor Wires, MGW Shifter, Street slayer twin carbon clutch, Tick braided clutch line & speed bleeder, ZL1 Diff Swap, BMR Split drop, Sway Bars, Trailing Arms, Toe Rods, Pro bushing kit, Carslyle racing 15in conversion, Whipple, LPE dual fuel pumps, Rx catch can, Id1300x, Alky Control
05-06-2010, 10:21 PM | #3 |
If thats what he means. Then yes it will over time cause problems. If not sooner.
Mods: BBK Intake, BBK LT's and High Flow Cats, Corsa Cat-back exhaust, Hurst short throw shifter, SLP skip-shift eliminator. 7/1/09 Placed order for IOM/IO int/ SS/RS 6M 9/26/09 Took delivery! |
05-06-2010, 10:24 PM | #4 |
Drives: 2010 Camaro 2SS LS3 6 speed IOM/IOM Join Date: Apr 2010
I'v been doing it to all my cars over the past 10 years (still own my first car and drive it too) and never had any trans issues, as long as your not grinding gears and it goes in to gear like butter, no damage will be done. You need to match the rmps with your speed and it will fall right in.
05-06-2010, 10:47 PM | #5 |
Yep! It seems to fall right into gear, no grinding or anything. I can't see it messing up the gears, only perhaps the synchros.
05-07-2010, 05:57 AM | #6 | |
Drives: 2010 2SS Join Date: Jan 2010
I know it is not exactly the same. Way back when, my 2nd car was VW Bug, drove that sucker without a clutch for a year. Would start it in gear and shift without any problems. It got to be a pain at lights and hills (using the parking brake). I wasn't a wrench back then, so it took me a year to actually check why I didn't have a clutch. Turns out the adjustment wing-nut by the bell housing had simply fallen off. Less than a buck and in 15 minutes the clutch was working again.
Aqua Blue 2SS c/w factory white strips, MT.
Installed options;Tinted Windows, De-badged, Hurst Shifter,CAI,Vmax throttle body, Kooks LT Headers, High Flow Cats,Borla Touring Axle Back, ADM Scoop, Washwater relocation,Diablo Predator(c/w Ted's Magic), Custom start defeat switch, painted engine cover, shark fin & bow ties, ABL lighting, Rear Camera. |
05-07-2010, 07:28 AM | #7 |
Turbos. Turbos. Turbos.
Drives: 2010 SS Yellow/Black Join Date: Nov 2009
You won't hurt anything as long as you don't clash the gears. Basically you are matching the engine speed with the driveline speed in a given gear. The clutch will live forever if you do it forever..but technically you can't.
I always slip the trans out of gear into neutral when I slow to a stop. If you feather the throttle it slips right out. And, if you don't actually have to come to a complete stop, you can easily slip it into first gear. Just beware if you miss your "opportunity" you'll clash the gears. Then, go back to basics.
05-07-2010, 08:52 AM | #8 |
The Mark of Excellence
Drives: 2010 ABM 1SS RS LS3 Join Date: Jan 2009
As soon as you know what the rpm differential between gears is you can upshift or downshift without using the clutch. The key is to have it slide in and out of each gear with no sound or feeling in the stick. Done properly I don't see how this can caise any damage. If it is done wrong or forced, that's a different story.
BMR, CAI, DynoMax, Elite Eng., Hurst, Jannetty, Clear Image Headers & Hi Flow cats, Jet Hot, LSR, TSW, VMax, Vredestein |
05-07-2010, 10:11 AM | #9 |
I'm too afraid of messing something up to even try doing this.
05-07-2010, 10:41 AM | #10 |
Drives: '10 CGM SS/RS Join Date: Nov 2009
Did it in my Jeep for the entire 12 years I owned it...never had a tranny isssue. Do it now in the SS as well. As long as it falls into gear with no ammount of force needed, you're good to go.
05-07-2010, 10:57 AM | #11 |
cool
05-07-2010, 11:46 AM | #12 |
Yep, that just happened.
Drives: Norma Jean, '10 Black 1SS/RS Join Date: Apr 2010
i suck at this.... always miss
K&N CAI
Doug Thorley Shortys Solo High Flow Cats Flowmaster American Thunder Catback BMR Stage 1 JRE Tune |
05-07-2010, 02:36 PM | #13 | |
Drives: Silver LS Join Date: Aug 2009
Silver LS - manual, white stripes, black interior, and those swell 18" black steelies! (18" Bavarian aluminum in the garage). |
05-07-2010, 02:44 PM | #14 |
Watch This!
Drives: Super Charged 1SS/RS, M6, CGM Join Date: Dec 2009
Why do this?
K&N CAI, Wet Okole Seat Covers, MagnaFlow Street Perf. Ex. (Axle Back), MPD Hood, Gary's Customz ZL1 Fascia/Vented Fenders/Custom Stripes/Paint, AAC Afterburners/Fog Light Halos/Side Markers/Misc LEDs, Bee-Otch Air Freshener, Hurst Shifter and Line-Loc(APEX), RPI Splash Guards, MagnaCharger (Texas-Speed)(Installed by ME), Rx Catch Can and Breather, Billet Pulleys (SC2150), ARH Headers, LPE Twin Fuel Pump, Custom Blower Cam, Custom Tune TBArwhp, TBArwtorq, Boost Gauge and Single Pod (MTI)
Similar Threads | ||||
Lowering springs and rear gears V6 information | macwest | 5th Gen Camaro SS LS LT General Discussions | 12 | 04-30-2010 10:58 PM |
Richmond Gears V8 and V6 - Group Buy | ZZcamaro | Transmission / Driveline | 175 | 04-30-2010 12:29 AM |
MTI Racing Review (Camshaft, Gears, Suspension, Handling) | Deric884 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 5 | 04-14-2010 08:11 PM |
NEW PRODUCT: 2010 Camaro Richmond Gears - 3.73 and 4.10 Ratios | tbyrne | Transmission / Driveline | 9 | 01-11-2010 10:36 AM |
Motive Gears says no Camaro Gears | ZZcamaro | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 60 | 01-07-2010 02:47 PM |
