Vararam
Old 06-16-2015, 10:13 AM   #1
MoCamaro20
MoCamaro20's Avatar
Drives: 2010 Camaro SS RS L99
2010 SS automatic cam quote
I am wanting to do a cam on my 2010 camaro SS automatic and I got a quote for everything he said around 3000$ for the cam and around 1900 for the torque converter. Does that sound about right?
MoCamaro20 is offline   Reply With Quote
Old 06-16-2015, 10:18 AM   #2
ClawSS
High-tech Redneck
ClawSS's Avatar
Drives: '10 CGM SS, '02 2500HD, '09 300SRT8
Did you get a parts listing for the cam install? and possibly a brand name of the T/C?
assumptions from your post is that this is a parts + labor quote.
<edit> Is there a dyno tune involved?
"My friends call me Chris. Are you my friend?"
2010 CGM L99 2SS/RS - GPI SS3 VVT, BTR DoD Delete, Circle D 4c, BTR springs, Katech C5R Timing Chain, MRR-228 315/275, CAI, Elite catch-can, TSP 1 7/8" Headers + offroad pipes, Magnaflow 3", Pfadt springs, BMR LCAs, toelinks, trailing arms, cradle bushings, & sway bars w/ endlinks, Vitesse paddles, heritage grille, and an eBay splitter. Power upgrades by Race Proven Perf.; Tuning by ShorTuning.
ClawSS is offline   Reply With Quote
Old 06-16-2015, 10:23 AM   #3
mjb_baldy
Drives: 2010 Chevy Camaro 2ss/RS
Check out RDP Motorsports here in Ohio.. If i recall it would be about $2500 and that included parts, labor, and dyno tune
mjb_baldy is offline   Reply With Quote
Old 06-16-2015, 10:28 AM   #4
MoCamaro20
MoCamaro20's Avatar
I'm not sure what cam to be honest. But is that 2500 including a torque converter
Old 06-16-2015, 10:31 AM   #5
MoCamaro20
MoCamaro20's Avatar
Sorry yeah that's with dyno tune parts and labor. So roughly looking at 4400-5000 for everything
Old 06-16-2015, 11:54 AM   #6
bmbbl be
bmbbl be's Avatar
Drives: 2010 CAMARO SS
you don't know what cam ?? why the torque converter ? unless you just want one
bmbbl be is offline   Reply With Quote
Old 06-16-2015, 12:34 PM   #7
ClawSS
High-tech Redneck
ClawSS's Avatar
sorry for the questions, but if you truly request a more accurate evaluation of your quote then some details are needed.
L99 cam swap will (most of the time) include a DoD delete regardless if VVT is kept or not. If so, then the labor will be all the way down to the shortblock and back up with new parts for the lifters, valley, etc. Most cams should also require new springs, too.
If you keep VVT, then cam phaser, if deleting VVT (not advised) then more parts for the deletion.
I would say if you go with BTR parts, and a custom cam...you should be right at $2500 parts + labor keeping VVT + fluids. $900 for a Circle D single clutch at 3200 rpm stall and around $300 for labor+fluids.
Bolts...standard or ARP? ARP would add a few hundred $$$ to the rebuild.
Honestly, it's close and may be worth the "extra" if it is a respected shop that will stand behind the build and tune to your driveability expectations.
That is my WAG on this. You already have headers?
camaro5
