01-29-2015, 06:31 PM | #1 |
Drives: '17 Zl1, '16 Viper ACR, '15 CLA 45 Join Date: Nov 2014
LS7 Engine Failure & Fire. Was Denided
I was with my good friend 2 months ago at VIR when his bone stock 8000 mile 2013 z06 Carbon blew an engine. He had a 2007 z06 which also blew at 30k miles but was ok after that for another 20k, gm fixed that one. I think it was a valve guide that time. One reason he upgraded to a 2013 is because we have "thought" they may have fixed the engine problem.This was the first time he took the car on track, we was only there for 1 day and it blew toward the end of the day. The bad part is the rear bumper of the car caught fire im guessing from unburn fuel after the motor blew, it went out very quick but melted the bumper. GM denied the claim today, saying he failed to follow the owners manual for track procedure????? The oil had 100 miles on it, oil levels was fine on track, etc, etc. We checked them in the pits as something you always do.
Its took nearly 2 months for them to get to this point, car has been sitting at local gm dealer for 2 months. He hasn't posted on the corvette forum or anywhere yet, because he is waiting to talk to them one more time before moving forward. I asked if he minded that i posted in hear as a warning if you will. Considering we share that engine that all brings me to this. One reason i purchased the Z28 is because i thought gm claims, that if you dont mod the car and do regular maintenance that they will warranty the vehicle for track use. The z06 manual tells you what to do for performance driving. This is very bothersome to me because his car is unmodified, and they simply denied his warranty. I personally know of around 10 ls7 that have blew up on track while i was there. Most i know have been covered. The only ones that haven't i read about have been modded with headers/pcm/cam etc, which i fully understand. Ive considered a new z06, have a 2015 3500 dually, and now this z28. Im hoping they make things right, but will have to wait a few more weeks to find out. Ill keep you updated. Last edited by lmcgrew79; 01-30-2015 at 07:45 AM. |
01-29-2015, 06:41 PM | #2 | |
SHKE BKE
Drives: 2013 Camaro Join Date: May 2014
01-29-2015, 06:57 PM | #3 |
Drives: 2006 Z06 Join Date: Oct 2010
Just like a new z06 owner went to the track, had an issue on a bone stock c7z, and it took the internet and a huge push on GM to get them to replace the tranny that would keep popping out of gear. If you track a car, i wouldn't expect warranty.
Nick
Corvette Z06 -1200ish rwhp |
01-29-2015, 06:57 PM | #4 | ||
Besides that I'm also curious like Tommy what exactly he did not follow, I also wonder what caused his engine failure in 2013 Corvette Z06. Was it that you suspect these LS7 engines may blow up after prolonged high reving?
01-29-2015, 07:02 PM | #5 |
Drives: 2011 2SS/RS LS3 Join Date: Nov 2011
This same issue was discussed in the 1LE forum recently.....Bottom line, is whatever the dealer deems as "abuse" rules the day and can void the warranty regardless of track-worthiness, etc....Good luck...
A lot of it depends on each one's "relationship" with their dealer.. Here's the link, if you're interested... http://www.camaro5.com/forums/showthread.php?t=391680 |
01-29-2015, 07:24 PM | #6 | ||
Not sure yet, they asked if he had done anything to the car, and he said no. Which is true as the car just came from the dealer 200 miles ago. He check the oil/brake fluid. That was the only thing they told him, im sure he will get a letter or something.
01-29-2015, 07:37 PM | #7 |
Nope, all LS7s from 06 to 2013 in the vette have dropped valves and had guide issues.
2012-2013 had serious bearing issues and a lot of people lost motors at early age from bearings.
Nick
01-29-2015, 07:42 PM | #8 |
01-29-2015, 07:46 PM | #9 |
this sucks...need a head swap on these motors ASAP to prevent the valve guide issue...that won't help the bearings. Are the Camaro LS7's prone to the same issues? GM resolved it maybe??
01-29-2015, 07:49 PM | #10 |
I have no idea, the only thing ive found is in a z28 650 video with John Hennessy, he mentions something about the head design being different. Maybe someone should call Hennessy Performance and ask.
01-29-2015, 08:05 PM | #11 |
KaBoom1701
Drives: 13' ZL1 Red M6 Join Date: Dec 2012
How many miles were on the car before he went to the track?
Mods:
Roto-Fab Intake, WW Res. kit & Big Gulp Air Scoop, Elite Catch Can, ATI Super Damper & 18% OD Pulley, LF Idler pulley bracket, Metco CC breather, ID850 Injectors, Stainless Power Headers w/ ceramic coating, TR71X Spark Plugs, JMS Fuel Pump Booster, Bo White TB, Tuned by Ted @ Jannetty Racing, Ron Davis HX, D3 Reservoir, Pfadt 1" Springs, Moreno Camber Plates, ZL1 Addons Splitter guard washers, Tow Hook kit & rock guards, Hurst Shifter Billet Plus 6 Speed Short Shifter, ZL1 DRL lighting harness, ZL1 Recaro Seats. |
01-29-2015, 08:07 PM | #12 |
01-29-2015, 08:08 PM | #13 |
KaBoom1701
Then I would run it up the GM ladder....something doesn't seem right?
Mods:
01-29-2015, 09:31 PM | #14 |
Very much doubt it. Z28 motors are just left overs from the vettes, no changes in part numbers or anything on the heads or motors. I would plan on checking the heads for wear at 10k and budget 2-3k for head rebuild.
It is already been hashed out on Corvette forum. Part number and everything for the z28 heads is identical, no changes to the vette heads. Hennesey was just spewing word vomit.
Nick
