BeckyD @ James Martin Chevy
Old 04-21-2023, 03:05 PM   #267
laynlo15
laynlo15's Avatar
Drives: 2022 Lt1 A10
Originally Posted by Nmolina9239 View Post
Laynlo, reference page 14 on this thread. My post #195 covered the measurements I took between the stock SS hood and the top of the blower. This is with the cradle spacers already installed. She’s a tight fit.
No kidding, I like the blower but I think that's the worst part is having to lower the cradle. I think Mike at TooHighPsi could build a shorter Billet lid for the 3.0.
Old 04-21-2023, 03:15 PM   #268
adamjwilson
Drives: 2022 Camaro 2SS A10
I think Josh and NMolina did use the cradle spacers and installed with cowl on, but I did mine with the motor out and put it back in with the motor and Whipple at one shot without the cradle spacers. Either way it is a tight fit, and my measurements were close to NMolina with the playdough and micrometer.
I would be all in if Mike could make a billet lid, because we all know Whipple isn't... lol
DSX Flex Fuel/ Meth Injection/ Katech 112 TB/ RotoFab Big Gulp/ Corsa NPP/ Various exterior mods
adamjwilson is offline   Reply With Quote
Old 04-21-2023, 04:34 PM   #269
laynlo15
laynlo15's Avatar
He couldn't do it. The lid has the intercooler lines and it wouldn't be cost effective to build a lid that housed those fittings.
Old 04-23-2023, 12:50 PM   #270
Nmolina9239
Nmolina9239's Avatar
Drives: 2018 2SS
Another Update - Smoothboost, Kong Porting, Katech P.I & more.
Gents,
Figured it was time for another update, been a while. I have struggled to work on the car recently with a busy work schedule. But here we go...
Working with Levon at Smoothboost, I was able to successfully install and test the device. He sent me a new bracket yesterday and some small spacers to try. Using one spacer and the new bracket was a success. Pictures and video attached. I mounted the adjustable controller in my arm rest cubby. I also got some badass steering wheel buttons from Motion Raceworks. The green one is for scramble mode. This allows for full boost even if I have the controller set half way for example. The Red button is for Boost cut incase things get a little sideways. I am interested in seeing if I can use the TooHighPsi Reflex controller to control boost in either direction for safety or even to control launches at the strip.
I sent the blower to get ported by Kong. Attached are some before and after pictures. He opened the snout to fit a 120mm TB if i wanted in the future. For now I plan on sticking with my 103mm. The TB adapter plate that Whipple sent me works still with my 103 after the porting.
Katech Mike hooked me up with the P.I machine work. I am currently wrapping up the fuel system and wiring etc for the injectors. Ended up buying 1050cc injector dynamics units to add to my already installed LT4 injectors on the DI side. Thanks Mike with the work and helping out with the fuel fitting against the EVAP solenoid issue.
Still have to order pulleys for when I go get tuned. Going to aim for 16/18/20 PSI setups to do some testing when the time comes.
Also order Viking Coilovers for all four corners for this year. Kelly at Kelltrac was great to deal with. Spent almost an hour on the phone with me explaining the differences between going Coilover or shock and spring package. I opted for the Coilovers fully assembled. He even provides alignment specs to use with them as well as shock settings for rebound and compression to use as a baseline based on your goals, power & weight etc Highly recommend.
Also need to wrap up my Cordes Ice Tank Install as well. Just need to run the lines from the trunk to the blower now. Probably be the last thing I do before start up.
-Norm
2018 Camaro, Whipple Charged, RotoFab Big Gulp, Katech 103mm, LT4 Fueling w/ JMS BAP, GPI Drop in Rods and Pistons, Custom Cam, Ported Heads, Kooks LTHs w/ Green Cats and Mid Pipes, Corsa Extreme Mufflers, DSS Driveshaft & CV Shafts, Might Mouse Catch Can, Circle D T.C. #Team GPI
Nmolina9239 is offline   Reply With Quote
Old 04-23-2023, 12:55 PM   #271
Nmolina9239
Drives: 2018 2SS
Anyone know how to upload a video? I wanted to load the Smoothboost video I took. TIA
Old 04-23-2023, 01:00 PM   #272
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
You have to use a host like YouTube or Google Drive.
2016 NFG 1SS A8
Options-2SS Leather/NPP
Old 04-23-2023, 01:03 PM   #273
Nmolina9239
Drives: 2018 2SS
https://drive.google.com/file/d/1DnT...usp=share_link
Old 04-23-2023, 01:36 PM   #274
Joshinator99
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Nice work, Norm! She’s going to be a beast!
Old 04-23-2023, 03:40 PM   #275
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
That's great info and pics!!! MAN - Kong ported the pizz out of that! NICE WORK!
'20 ZL1 Black "Fury"
Old 05-10-2023, 05:35 PM   #276
Nmolina9239
Drives: 2018 2SS
Does anyone have experience installing the Cordes trunk ice tank or another forum post/video? Trying to see if I can run both lines down the driver side through the fenders and side skirt.
Old 05-10-2023, 05:38 PM   #277
Joshinator99
You can, take a look at the Synergy trunk tank and they show you how to run the lines like you want.
That said, I got the lines up to the front without having to do that. Tucked them along the pinch weld and used the existing OEM fiber panel retaining studs/nuts to add coated clamps. With the fiber panels back up you really cannot see the hoses.
Old 05-10-2023, 08:24 PM   #278
Nmolina9239
Drives: 2018 2SS
Thanks for the info once again Josh.
Old 05-10-2023, 08:29 PM   #279
Joshinator99
FYI since I’m in a roll lol… the 3.0 has inlets and outlets on opposite sides of the blower. That pic I posted was from when I was running the 2.9 blower. I ended up rerouting my ice tank lines so that the supply went up the passenger side and the return back went along the drivers side. So not sure if maybe that’s a better way for you to go.
Old 05-10-2023, 10:19 PM   #280
laynlo15
laynlo15's Avatar
Good thinkin Tex.
