AWE Tuning
Old 03-15-2023, 09:39 PM   #197
Joshinator99
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Originally Posted by Nmolina9239 View Post
Gents,
I throw the blower back on my car and took some pictures with playdough (yes I have some at home, my gf is a teacher).
I also took some measurements using a micrometer as shown. This is on my 2018 SS with the stock hood (including the felt protector underneath) as well as the cradle lowering spacers as I posted pictures of before.
Long story short, she appears to be a tight squeeze. I had spoken to Grant at TooHighPsi a while back and he mentioned that even their low profile plates are 8/10ths of an inch thick. Looks like machining the intake runners is the way to go unless I'm missing something.
Hope this helps.
-Norm
Nice work Norm! Very helpful!
It appears that this confirms spacers are not needed on an SS. I know you’re running them, but the spacers are 0.375” if I’m not mistaken. So even the tightest spot was 0.631” with the spacers installed…so without the spacers you’d still have nearly 0.300”. And that’s with the hood liner too. Just my thoughts.
Edit: Also, I agree on the runners needing to be machined. They were obviously designed to accept port injectors since the bosses are cast in. And since the runners can be easily separated and shipped out for machining… no brainer. Adding plates would be crazy IMO.
Joshinator99 is online now   Reply With Quote
Old 03-16-2023, 05:51 AM   #198
adamjwilson
Drives: 2022 Camaro 2SS A10
Thanks Norm as you have the same hood as Josh I believe. My hood configuration is different, but I will still measure for peace of mind on Friday.
Edit: Also, I agree on the runners needing to be machined. They were obviously designed to accept port injectors since the bosses are cast in. And since the runners can be easily separated and shipped out for machining… no brainer. Adding plates would be crazy IMO."
Agreed... I am still waiting on Katech to finish his preliminary work and find out the costs as he is offering this service soon!
DSX Flex Fuel/ Meth Injection/ Katech 112 TB/ RotoFab Big Gulp/ Corsa NPP/ Various exterior mods
adamjwilson is offline   Reply With Quote
Old 03-17-2023, 07:21 AM   #199
Nmolina9239
Nmolina9239's Avatar
Drives: 2018 2SS
Same my friend, I am going to reach out to Mike today to see how far they think they are out. At some point I gotta make a call to keep just direct or keep waiting to keep my build going. You only get a few months a year in NY to drive before winter comes back lol.
I am also checking to see how I can combine the Smoothboost controller I bought with the TooHighPSI port controller I have. Lots of wiring to do still.
2018 Camaro, Whipple Charged, RotoFab Big Gulp, Katech 103mm, LT4 Fueling w/ JMS BAP, GPI Drop in Rods and Pistons, Custom Cam, Ported Heads, Kooks LTHs w/ Green Cats and Mid Pipes, Corsa Extreme Mufflers, DSS Driveshaft & CV Shafts, Might Mouse Catch Can, Circle D T.C. #Team GPI
Nmolina9239 is offline   Reply With Quote
Old 03-17-2023, 08:00 AM   #200
Katech_Mike
Drives: 2015 Camaro ZL1
I didn't forget about you guys.
We're almost there!
Katech_Mike is offline   Reply With Quote
Old 03-17-2023, 08:00 AM   #201
Joshinator99
Did you put the Smoothboost on the 3.0 yet? I know Smoothboost does not have the bracket to mount the actuator to the new blower yet. Shouldn’t be too hard to make one up custom I guess.
Old 03-17-2023, 08:01 AM   #202
Joshinator99
We're almost there!
Looking good Mike!
Old 03-17-2023, 08:05 AM   #203
Nmolina9239
Drives: 2018 2SS
We're almost there!
Looks awesome Mike! I'm ready to order lol
Old 03-17-2023, 08:08 AM   #204
Nmolina9239
Drives: 2018 2SS
Josh, I got a hold of Levon at Smooth Boost and he sent me the Edelbrock blower bracket. i did a quick install and it fits but I have not function tested it., will check to see if I have pictures somewhere. I have a variable DC power supply on its way to use to for testing purposes instead of cutting into my harness for the gas pedal.
I am going to call TooHigh today to see if I can use one of the outputs from their relfex controller to provide the 1.5-5V signal to the smoothboost controller.
More to come.
Old 03-20-2023, 01:30 PM   #205
Katech_Mike
https://katechengines.com/i-30498203...ction-kit.html
Port injection machining is live!
I'll try to grab a few pictures showing the disassembly process when I get time as well.
Old 03-20-2023, 02:01 PM   #206
laynlo15
laynlo15's Avatar
Drives: 2022 Lt1 A10
So basically you'll have around 900.00 with shipping to and from Katech. Reflex Controller 1200.00 plus plumbing, fuel rails and injectors. So it's going to be similar to buying a complete kit from THPSI, but the plates would make it tough because they are 3/4 inch and the 3.0 is so much taller, you'd need the cradle spacers to clear the cowl. Seems like a great option and a fair price, nice job from the guys at Katech and Whipple for having the additional bungs to add the injectors.
Old 03-20-2023, 06:02 PM   #207
Joshinator99
More to come.
Be careful…I think the Smoothboost actuator shaft as delivered for the 2.9 is too long based on my initial mock up. The 3.0 vacuum bypass is definitely shorter than the 2.9 version was. I sent Levon some detailed side-by-side pics yesterday but haven’t heard back yet.
Nice work Mike! That’s definitely in my future later this year.
Old 03-20-2023, 06:19 PM   #208
Nmolina9239
Drives: 2018 2SS
Thanks for the heads up Josh. I sent the blower to Kong for porting so I’ll mess with it when it gets back.
Just sent my intake runners to Mike for the PI as well. Thanks for putting that program together Mike.
Old 03-20-2023, 06:59 PM   #209
Joshinator99
Here’s what I’m talking about in regards to the actuator length:
Old 03-24-2023, 02:40 PM   #210
Katech_Mike
Has anyone posted results with the 3.0L yet?
My customer finally dropped the car off today. He decided to upgrade to a Fore triple and Cordes ice tank. We're going to shoot for max blower speed and see what it makes.
