03-14-2023, 01:54 PM | #183 | |
Without the spacers, if you launch the car hard, I wonder if the blower could hit the cowl…? Does the lid have any clearance to the cowl? Hurry up and test your car on the street for me! You could be 100% right on this… Doesn’t the ZL1 have a bit less hood clearance than the SS? Wonder if maybe that’s where the spacers are needed (in addition to C7 Vette)?
03-14-2023, 02:16 PM | #184 |
Yep that's right the ZL1 has less clearance due to the hood and you have to trim it for even the 2.9.
2016 NFG 1SS A8
03-14-2023, 04:57 PM | #185 | |
Drives: 2022 Camaro 2SS A10 Join Date: Jul 2022
I have broke enough s**t over the years with bikes and boats... and all those crazy hobbies takes alot of cash to maintain and fix. So I will sit on the sidelines for you guys with the 1000hp cars and watch you tear stuff up this time around
DSX Flex Fuel/ Meth Injection/ Katech 112 TB/ RotoFab Big Gulp/ Corsa NPP/ Various exterior mods |
03-14-2023, 05:19 PM | #186 | |
When you get a chance will you take a closer look (and maybe a pic) of your cowl to blower clearance?
03-14-2023, 05:34 PM | #187 |
Is it possible that the hood is an issue with either '16 - '18 or '19 & up, but not both? The hoods are slightly different after all.
Baby Blue
03-14-2023, 07:19 PM | #188 |
I guess we’re going to find out…
03-14-2023, 09:08 PM | #189 |
I would think the 16-18 hoods have the most clearance since they don't have the heat extractor in the middle of the hood.
2016 NFG 1SS A8
03-15-2023, 06:13 AM | #190 |
I need to go back to the shop soon and see the clearance when the hood is shut again. Not sure how to measure or take pic of that clearance? (any ideas Josh) but I know the hood shuts. The lid sits behind the heat extractor vent in the middle of the hood if I am not mistaken on my '22...
03-15-2023, 07:14 AM | #191 | |
Drives: 2017 Camaro SS 50th Anniversary Join Date: Apr 2021
2017 50th Anniversary Edition | P1X Stage 2
DSX Aux Low Side | LT4 high side | Flex Fuel TooHighPsi Port Injection (installed & tuning) CircleD 3K Stall | QA1 CF Driveshaft Forgestar F14 Drag 17x10 NT555R2 305/45/17 Rear Forgestar F14 18x8 NT555G2 235/50/18 Front 10.84@131 w/4.13" pulley ??.??@??? w/3.7" pulley (installed & tuning) |
03-15-2023, 07:19 AM | #192 |
Josh wanted a pic of the clearance... was going to use tape, but aluminum foil is a good idea too.... not many of us do not have playdough laying around if we don't have young kiddos... lol
DSX Flex Fuel/ Meth Injection/ Katech 112 TB/ RotoFab Big Gulp/ Corsa NPP/ Various exterior mods Last edited by adamjwilson; 03-15-2023 at 07:32 AM. |
03-15-2023, 07:47 AM | #193 |
If the hood shuts, then that’s fine. I was more curious about clearance to the windshield cowl… which you can obviously measure and photograph with the hood up.
03-15-2023, 12:05 PM | #194 |
Josh- I plan on stopping by the shop on Friday and will get you the info and pics. Damn work has me tied up until then and I need see if the Katech TB fits the snout as well.
03-15-2023, 07:22 PM | #195 |
Drives: 2018 2SS Join Date: Sep 2018
Gents,
I throw the blower back on my car and took some pictures with playdough (yes I have some at home, my gf is a teacher). I also took some measurements using a micrometer as shown. This is on my 2018 SS with the stock hood (including the felt protector underneath) as well as the cradle lowering spacers as I posted pictures of before. Long story short, she appears to be a tight squeeze. I had spoken to Grant at TooHighPsi a while back and he mentioned that even their low profile plates are 8/10ths of an inch thick. Looks like machining the intake runners is the way to go unless I'm missing something. Hope this helps. -Norm
2018 Camaro, Whipple Charged, RotoFab Big Gulp, Katech 103mm, LT4 Fueling w/ JMS BAP, GPI Drop in Rods and Pistons, Custom Cam, Ported Heads, Kooks LTHs w/ Green Cats and Mid Pipes, Corsa Extreme Mufflers, DSS Driveshaft & CV Shafts, Might Mouse Catch Can, Circle D T.C. #Team GPI
03-15-2023, 08:55 PM | #196 | |
