02-14-2023, 08:27 PM | #155 |
I mounted mine on the backside of my Rotofab Big Gulp heat shield (the 2 small stainless button head screws mount it to the heat shield). Tough to see, but it’s there and has worked out well. The -10 AN fuel line runs up to the HPFP tee then continues on to the regulator. From the regulator the -8 AN return line runs back to the tank (ethanol sensor is in the return line too). Running those fuel lines was a time consuming endeavor… don’t skimp on high quality fire sleeve either. Hope that helps!
02-14-2023, 08:34 PM | #156 |
Drives: 2018 2SS Join Date: Sep 2018
That idea came up but I was nervous about it bouncing around for some reason. I was going to mount it right in that same location but just off of the shock tower. Made a template for a bracket to cut out using the two bolts that the Whipple fill bottle bracket mounts onto. Thanks for sharing Josh
2018 Camaro, Whipple Charged, RotoFab Big Gulp, Katech 103mm, LT4 Fueling w/ JMS BAP, GPI Drop in Rods and Pistons, Custom Cam, Ported Heads, Kooks LTHs w/ Green Cats and Mid Pipes, Corsa Extreme Mufflers, DSS Driveshaft & CV Shafts, Might Mouse Catch Can, Circle D T.C. #Team GPI
02-14-2023, 08:39 PM | #157 | |
Happy to help! Post up some pics when you’re done.
02-15-2023, 03:38 PM | #158 |
Drives: 2017 Chevrolet Camaro ZL1 Join Date: Jul 2018
Vengeance has one of these in stock ready to ship if anyone is looking. Just saw them post it today. It is the polished style and was a replacement for a failed 2.9, but the customer went a different direction I guess.
2017 ZL1 - PB 8.05 @ 172 MPH @ 3730 lbs @ 70 DA (work in progress)
Built by Vengeance Racing, tuned by Elite Tuned |
02-15-2023, 04:53 PM | #159 |
No thanks. I've spent enough on this rig!
'20 ZL1 1LE A10,
02-27-2023, 02:11 PM | #160 |
Anyone having any luck with getting Port Injection setup?
02-27-2023, 07:44 PM | #161 |
Old badass
Drives: 14GMC 2.9 16GMC Turbos 2020Silv.6.2 Join Date: Mar 2020
My daily ride is a 6.2 truck. Chris Crawford said he could do the mod on my 3.0 manifold since I have no room for the plates apparently. At least I have an option.
I've had 7 Camaro's. All gone...for now.
Current build in progress 2016 GMC4x4 RCSB twin hair dryers ~1k whp fbe port inj 1/8 mi & stealth street terror |
02-27-2023, 08:06 PM | #162 |
Katech was supposedly working in this port injection mod to the Whipple 3.0 runners too, not sure where they are with that.
02-28-2023, 06:24 AM | #163 | |
Admittedly taking longer than I'd like but we have to clear out some other current projects 1st. I'm hoping to have it completed in the next few weeks. |
03-13-2023, 10:52 AM | #164 |
Drives: 2022 Camaro 2SS A10 Join Date: Jul 2022
Getting closer to finishing- man that lid is huge on the 3.0
Need to look for a larger TB as the 95 is dinky- looks like a Katech is in my future. Anyone running the 120mmTB from Katech? Dan @ Katech says the snout needs to be ported to accommodate the 120mm TB, so 112MM may be a safe bet.
DSX Flex Fuel/ Meth Injection/ Katech 112 TB/ RotoFab Big Gulp/ Corsa NPP/ Various exterior mods Last edited by adamjwilson; 03-13-2023 at 12:43 PM. |
03-13-2023, 01:23 PM | #165 |
Speaking of Whipple 3.0, look what just arrived…!
03-13-2023, 03:22 PM | #166 |
You gonna like the upgraded version from what I hear....
DSX Flex Fuel/ Meth Injection/ Katech 112 TB/ RotoFab Big Gulp/ Corsa NPP/ Various exterior mods |
03-13-2023, 03:32 PM | #167 |
Drives: 2017 Camaro SS 50th Anniversary Join Date: Apr 2021
Oh, I see they shipped my Whipple 3.0 to you by mistake. I'll just give you my address and you can send it along, k?
2017 50th Anniversary Edition | P1X Stage 2
DSX Aux Low Side | LT4 high side | Flex Fuel TooHighPsi Port Injection (installed & tuning) CircleD 3K Stall | QA1 CF Driveshaft Forgestar F14 Drag 17x10 NT555R2 305/45/17 Rear Forgestar F14 18x8 NT555G2 235/50/18 Front 10.84@131 w/4.13" pulley ??.??@??? w/3.7" pulley (installed & tuning) |
03-13-2023, 05:19 PM | #168 |
Sure LMAO
