04-24-2024, 11:02 PM | #1 |
Drives: 2012 Camaro 2SS/RS Join Date: Jul 2010
Going on rear, leave front as is?
I want to move up from 295s to 315s on the rear, but not sure if I should leave the front be? They're currently 275/35. Also, wondering if I should get a 275/40 instead? I see 40 is the recommended size, but I've been running 35s all this time. I don't think the tires came in a 40 back when I got them.
Finally, what is the best place to buy? I emailed Tirerack to ask these questions, but no one responded yet. I also emailed the vendor where I bought my original PSS tires over a decade ago, but no reply from them, either.
04-25-2024, 07:11 AM | #2 | |
Drives: 2011 2SS/RS, '22 Silverado Z71 Join Date: Sep 2010
I just bought a set of Hawk ceramic brake pads from Tire Rack and one guy actually gave me the correct part number for the rear eventhough they did not have a listing for them when you searched the car on their website. I actually got the same part number direct from Hawk when I was actually able to get through to them... when I went to order them I had to call or chat to place the order and "it was on me if they weren't the correct pad"
04-25-2024, 01:54 PM | #3 |
Thanks, I could try calling them. They said they'd reply to my email in 2 days, but no joy yet. I wouldn't think I'd have to beg someone to take my money, LOL.
My main question is, what's the diff between these two tires. This is what I want for the rear, but one says Ferrari and the other says Porsche, but they both appear to be the same size??
04-25-2024, 02:40 PM | #4 |
It's not that unusual to find "special" tires for the high end car brands. It can be a slightly stiffer sidewall, a slightly different compound, etc. You would probably have to get on forums for those brands to try and find out what the difference is.
Also found this https://www.tirerack.com/upgrade-gar...41fb130a82b821 |
04-25-2024, 10:52 PM | #5 |
Thanks! So, I'm guessing either one would work OK? Ferrari sounds cooler, LOL, so maybe I'll just go with that one.
04-26-2024, 07:59 AM | #6 |
If you compare the two with Tire Rack compare feature, the Ferrari is slightly heavier with slightly more tread depth and width. But I don't know how accurate that is.
