12-29-2020, 02:01 PM | #1 |
Drives: 2014 camaro ss 1LE Join Date: Apr 2020
how small of a rim can i go
I am working my car over quite a bit this winter.
should put around 1,000 to the tires and wanna work on getting some traction haha. Was debating on going to a smaller wheel to gain some side wall wrinkle but was not sure how small of a rim i can go down to without needing to look into a conversion kit.
2014 SS 1LE summit white
RWHP 1032 Modifications are as follows: Engine, forged and stroked 416 CI, Procharger F1A-94 with upgraded race intercooler and big red blow off valve, HP Tuner, AEM Wideband with Gauge, TSP Supercharger Camshaft 224/240 .615/.615 112 +3, Brian Tooley Dual Valve Springs, Brian Tooley Chromoly Pushrods and ported heads. Fore innovations twin 450 pumps on E-85 Brian Tooley Titanium Retainers, GM 3 Bolt Conversion, New GM Oil Pump, Injector Dynamics ID 1700 Injectors, Kooks 1 7/8" Long Tube Headers , |
12-29-2020, 02:54 PM | #2 |
Onyx_Z7 <— Instagram
Drives: 2013 2ss 1le Join Date: Aug 2014
I think 17s but you might need a bmr lower control arm that has the notch for clearance
12-30-2020, 10:14 AM | #3 |
Tri-County Camaro SWFL
I think 18 but if you go with Welds then 17. And ziptie the e brake cable
12-30-2020, 11:58 AM | #4 |
Thanks for the insite.
Still debating on even going with a true wrinkle wall toyo r888r makes a 20 inch radial that im thinking of trying out first.
