Old 08-23-2020, 09:54 PM   #1
Pearlj10
Drives: 2011 Camaro 2LT
JMS BAP Wiring
I’ve seen a few ways of wiring these, and some moderately heated discussion about what’s right/wrong. This is what I’m planning on doing with a target output of 17.5V. I’ll be adding an inline 30A fuse to protect the white wire going to the FSCM, since I’ll be bypassing the F12 fuse box in the trunk entirely. Input is most appreciated. Thanks
Pearlj10 is offline   Reply With Quote
Old 08-23-2020, 10:41 PM   #2
Rons1le
Rons1le's Avatar
Drives: 2015 Camaro 2SS RS 1LE AGM
Exactly how I installed mine, fuses and all. And mine is in the battery well just like FasNuf did in his youtube video. And my voltage is set at 17.5 vdc also.
Sent from my SM-G960U using Tapatalk
2015 2SS RS 1LE NPP/w Kooks headers, Procharged, ID1050X injectors, Katech belt tensioner, Mighty Mouse Catch Can, BMR subframe connectors, Matco driveshaft loop, AEM Wideband/Boost/Fuel gauges , Z/28 Splitter and Spoiler/w Wicker bill, Power Stop rotors and brake pads, MRR Z/28 Rep Wheels 20" w/p zeros 285 fronts and 305 rears, ZL1 addons Rock guards and Tow hook, Rear window louvers, Flags on the quarter windows and the moonroof, Billet aluminum door handles.
Rons1le is offline   Reply With Quote
Old 08-23-2020, 10:50 PM   #3
FasNuf
FasNuf's Avatar
Drives: 2014 Camaro ZL1
Did someone mention my name? LOL
Here's the Install Video
https://youtu.be/PgeWAhuN2zM
Voltage Monitor Gauge video
https://youtu.be/TmeU7fCKt2Y
FasNuf is offline   Reply With Quote
Old 08-24-2020, 08:02 AM   #4
Greenhornet2
Greenhornet2's Avatar
Drives: 2011 Camaro 2SS LS3 Whipple
yup looks good. I stayed just under 17.5V 17.42V I think I got as I was told by Jannetty I should go over 17.5 and the next notch on the adjustment put me over 17.5
Greenhornet2 is offline   Reply With Quote
Old 08-24-2020, 09:41 AM   #5
Pearlj10
Thanks all. Nice vids FasNuf! Thanks for posting those links.
Old 08-24-2020, 09:45 AM   #6
FasNuf
FasNuf's Avatar
That's why I make them. So glad they help someone.
bap, boost-a-pump, jms
