TireRack
Old 02-27-2024, 02:43 AM   #1
IKILLEDSUPERMAN_ZL1
Drives: 2011 Camaro SS
Caddy lifter preload
What are you guys that run these lifters running for preload? .100 or less?
IKILLEDSUPERMAN_ZL1 is offline   Reply With Quote
Old 02-27-2024, 05:08 PM   #2
morepowerjoe
morepowerjoe's Avatar
Drives: 2012 Chevrolet Camaro l99
I try to get in between .060-.080
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817
morepowerjoe is offline   Reply With Quote
Old 02-28-2024, 06:50 AM   #3
acammer
GPI Sales Consultant
acammer's Avatar
Drives: 2011 Camaro 2SS SGM
They are pretty happy with anything like you would do with a stock LS7 lifter. We target anywhere from .050" to .130" depending on the application. If it's tight on PTV, we'll lean towards the light side, if that isn't a concern you can put a little more to them to reduce the room for squish. The lifter itself doesn't really care too much where in the preload range it is, as long as it's not bottomed out, or seeing lash when everything is warmed up and grown.
